Question about Vehicle Parts & Accessories
Remote car starter
My command start starts my car but shuts off right away?
    Master:
  • Vehicle Part... Master
  • 377 Answers
Have it re-programmed
Posted on Oct 22, 2013
  • 34 Answers
SOURCE: Remote car starter problem.....?
need to know what car and model of unit you have . it is a sec. or ignition wire problem
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: Mopar remote starter will start and turns off right away
My Fiance' had the same problem as well as an issue with the key fob not working properly. We took it to the dealer and they replaced the ignition switch which fixed the problem.
Posted on Mar 10, 2009
  • 439 Answers
SOURCE: i have installed a bull dog remote starter on my
This would only happen if you did not install the brake cut off switch. You will be able to shut the car off with the key after 15 minutes or with the remote.
Posted on Oct 31, 2009
Testimonial: "Thanks for the help, It solved my problem. "
  • 29 Answers
SOURCE: I have a remote car starter on my 2004 chryler
The 2004 Town and country has a factory anti-theft immobilizer which uses a chip in the key. Without bypassing the immobilizer the vehicle will not run (the anti-theft disables the electronic furl pump). Is the factory security light on the cluster flashing when you try to remote start? if so, Re-check the bypass unit that was installed with the remote starter, the transponder should be mounted at the ignition switch, it could of slipped off. It is possible that it has lost its programming or even failed completely.
Posted on Jan 10, 2010
SOURCE: manual for a command start cs 555 remote starter
Go to www.commandocaralarms.com to download install and owners manual.
Posted on Feb 13, 2010
Remote start works but shuts off right away
When you say right away....it is as soon as the vehicle starts....or is it 10-15-30 seconds later? Is this a factory remote start? If not, and you installed an aftermarket one, what is probably occurring is that your factory anti-theft system is seeing the vehicle running without the key in the ignition and activates the immobilizer which shuts down the vehicle. Aftermarket remote starts require adapter electronics to bypass the immobilizer until the operator enters the vehicle and inserts the key. This is why most aftermarket alarm systems are installed by trained pros.
Nov 05, 2013 | Dodge Grand Caravan Cars & Trucks
Remote car starter starts vehicle but vehicle shuts off right after
you have "lived" with for 14 years now so why are u trying to fix it now?????????
anyway find where remote starter's relays are under dash test the relays... one of them is broken or not wired right.
May 15, 2017 | GPS
I have 2002 avalanch that won't start guy told me that it was remote start problems could that keep it from starting with the key?
what does it do? does it turn over will not fire? not turn over or turn over and die right away? need some more info before i can give more detailed advice, the remote start shouldnt hold it up unless its a alarm/starter with the starter disable active.
Sep 06, 2011 | Chevrolet Avalanche Cars & Trucks
My remote starter is cranking the car but as soon as it cranks the remote starter is shutting right off. It does this every time I try to use it.even when I start the car by hand and then try to activate...
Hi This is an earth problem you need to ensure your starter is earthed properly or renew the earth cable is best this should solve the problem. Please leave me feed back: Malcolm Campbell, Thanks.
Dec 03, 2017 | 477L Ask RXTX HHU Remote
My vehicle starts but then quits right away. As I walk towards my vehicle it starts on it's own, but then still quits.
All directed electronic starters have a feature that when you go to start it by the remote if the car didn't start the first time then it will try 2 more times and after the 3rd try it will just not try again. Depending on the car it can be a security bypass that is not allowing it to stay running or it can be a problem not knowing the car has started and it shuts itself down. You need to make sure the starter is connected to the tach signal so that it can stay running for you. This is the best way for the starter to know your car is running and will not shut itself down.
Jan 18, 2011 | Remote Start System
I have a Command Start remote starter and the remote is worn out and buttons are terrible where can a person get a replacement remote but I dont know model number as there is no markings on remote it was...
Command Start was an AstroStart brand, you need to find a dealer in order to get a replacement remote. They do not sell via the internet. The following link will assist you in finding a dealer near you.
AstroStart dealer locator
Nov 12, 2010 | AutoCommand Remote Car Starter Add-On
Manual for a command start cs 555 remote starter
Jan 12, 2010 | Remote Start Alarm
IMy problem is when Iuse my remote command start
There are fail safe's with remote starters here is the list of things to check
Hood Switch: Designed so the car wont start with the remote if your hood is opened. (If this goes bad your remote start will think the hood is open and wont start your car!)
Break Switch: It will shut the car off if someone pushes on the break without a key in the ignition so no one just drives off with your car.(if this is bad it could be reading that your brake peddle is being pushed without a key in the ignition)
And Finally The Time Out.: This is designed so if you start your car and forget about it, you dont use all your gas or let the car run all day, typically they shut off after 20 minutes.(Your timer is programed into the main control box, If your timer goes bad it can cause the whole remote system to fault.
Anyway hope this helps. Check your switches before you presume that the unit is shot!
Oct 11, 2009 | 2003 Ford Windstar
Mar 06, 2009 | Chrysler Pacifica Remote Start, Two Way...
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
