Question about Cell Phones
Blackberry 8330 says "call failed please try again" when making a call but I'm able to receive calls.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Checked the call settings of your phone or go ahead and perform factory rest on your phone, which is available in the settings section of your phone. default pass for security is 12345 or any password you set it to
Posted on Oct 22, 2013
nightlisa
  • 102 Answers
SOURCE: Verizon 8330 does not ring
1. Check and make sure you're call forwarding settings are correct. Normally people have it set to ring for 20 seconds, before forwarding to voicemail. Your cell phone company should be able to walk you through what their default setting recommendation is.
2. Is the call making it to the device, but the ringer isn't turned on? Does the screen show INCOMING CALL? If it does, check your PROFILES and find out which one is active and see if the ringer for that profile is set to SILENT.
3. If the call never makes it to your BB, your internal antenna is bad - take it back.. or you get no signal where your at. Basic troubleshooting for the BB should be to pull out the battery. Turning it off completely by removing the battery - should reset any bugs that hose it up.
Posted on Mar 25, 2009
SOURCE: Not able to make outgoing calls
I cannot make outgoing calls with my iphone. It will show Calls Ended, Calls Failed. Any idea what is the problem with my iphone?
Posted on Jul 04, 2008
Blackberry_U
  • 223 Answers
SOURCE: BLOCK CELL NUMBER WHO CALLS AND TEXT ON MY BLACKBERRY 8330 CURVE
You will have to block the number with your wireless provider.
Posted on Jun 17, 2009
  • 93 Answers
SOURCE: call failed
You can refer this
Posted on Sep 22, 2009
akhtark74
  • 85 Answers
SOURCE: i have no service to my blackberry curve 8330,
If you are getting X means your service has been stopped from mobile carrier or your SIM card is damaged. Contact your mobile carrier.
Best Regards & Thanks
Akhtar Mohammad Kalim
Posted on Mar 30, 2010
Bought sim card in Cambodia for my blackberry. I can text and receive texts, but when I make a call to the same number (home, USA, CAlif) it doesnt work. How come I can text the number, but not call?
Derry, if your numbers are starting with 00 and then countrycode then local number, if yes change initially 00 with +, and then try again, if no then edit number and insert + and country code, then try to make a call. if problem persist try to check your call settings for international calls if is not a barred if yes then remove all barring calls, if problem persist try to do factory reset of device.Best of Luck.
Jul 16, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
Cannot sed/receive emails nor text messages. Reset has not helped. Many times!!!! 8330, verizion
If you think it's just a bad signal, Call *228 then option 2. This should update your PRL if it is not current, or at least maybe reset the phone with the cell towers. If that doesn't work try again but do option 1 instead.
Jan 21, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Can make outbound call on Blackberry Bold. Bought 2nd hand unlocked unit from the US. Can receive calls but everytime I try to make outbound calls it says: "Call failed due to SIM Toolkit control error....
This error is due to having an old SIM card.
Please talk to your carrier to get the latest SIM card.
You most likely have received an old SIM card batch.
Hope it helped.
Nov 23, 2009 | RIM BlackBerry Bold Smartphone
I just need the unlock code for the blackberry curve 8330
Unlocking is very easy Just purchase the code from http://mobile-unlokcer.com/ then get the instructions from http://www.mobileunlockguide.com/mobile-phone/3848/blackberry-curve-8330/ unlock your mobile
Nov 06, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry Curve 8330 call problems
well the phone is a really good phone, I would look at your provider.
on a regular day how long does your battery last? is it lasting less and less.
One of the nice things about the blackberry is you have the ability to reinstall the software if you need to.
so try what you can and if all else fails, do a reinstall of the software.
or download the desktop manager from blackberry.com and update your software.
maybe that will help.
good luck
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Get error messages when sending or receiving MMS on Blackberry
YOUR BB MMS SETTINGS IS CORRUPTED SO CALL YOUR SERVICE PROVIDER AND ASK THEM TO SEND THE MMS SETTINGS TO YOUR BB.
Apr 28, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry curve 8330's blocking mobile network
Sounds like you're in a dead zone. If not then ...
Check in the upper left corner... IF:
1x = you are not connected to any data at all - No emails, text, internet will work send/receive.
1xev= you're connected to data but not blackberry usually the same as above though sometimes you might get lucky and receive only text/pix messages.
1X= Phone calls only. Usually no data (email, text, web, etc)
1XEV = everything is connected and you should be working fine.
If you have 1XEV (upper case and lower case matter ALOT...everything should always be UPPERCASE) and you're still having that problem then go to:
options> advanced options> host routing table
In the host routing table click the button to the left of the roll ball (called the blackberry button) and click on "Register now" and just leave the phone alone for a minute so it can register all your service books again. Then try the web again.
If all else fails pullthe battery and try again ..> Still no good? Call your carrier.
Hope this helps
Mar 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Can't receive or make calls, texts
you can try taking the battery out of the phone and try again..............if not then take the phone to a mobile service center and have it checked.
Feb 17, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
