Question about Saeco Magic Comfort Plus Espresso Machine
Water leaks out under the brew group when brewing coffee
    Habit-Forming:
    New Friend:
  • Saeco Expert
  • 122 Answers
Maybe you have to change the small thing which is like a pipe on the brew unit
Posted on Nov 29, 2013
4 Suggested Answers
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
  • 1089 Answers
SOURCE: son in law added whole beans in ground coffee
The notches should be at 10 and 12 approx. If the noise is a clicking sound you have a broken brew drive, and the gears have to be replaced. The brew unit can't compress whole beans and something has to give.
There are to triangles on the front of the brew unit at the round hole where it piviots. They need to be pointing at each other, if the 2 notches are in the correct position, its ready to install
Posted on Dec 03, 2010
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Water coming from machine when brewing coffee water looks like coffee, brown in color and appears to be coming from brew group area. i have a saeco odea go machine. well maintained
there is excess water that comes from the injector when the brew group disinguages it. make sure the path is clear of coffee grounds in such. Some other things to check are the conditions of thr o-rings there are to 2 on thr injector inside the machine and one on the brew group if there damaged at all they will leak.
Dec 14, 2009 | Coffee Makers & Espresso Machines
Is my "brew group" broken.
Remove the brew unit, under the white plastic valve you will notice a small chamber that might be filled with coffee grounds and water. Clean chamber.
Dec 01, 2009 | Saeco Vienna De Luxe Espresso Machine
I have water leaking from under and I cannot see where it is from. I have taken the brew group out and cleaned but it still appears.
try this:move brew unit and you will see white brew valve,clean inside sometimes coffe stuck inside and dont draining water from valve in tray
Aug 20, 2009 | Saeco Vienna SuperAutomatica Coffee...
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
The grounds are sloshy and the coffee is weak - I think that the coffee is leaking out as the hot water is being pumped through the ground beans
I think I have the answer to this: when mine started doing the same thing, I found that coffee grounds had accumulated and were blocking the seal of the water supply with the brew-group.
The Behind the brew-group is a clear tube with o-rings that slides into the brew group to supply water. One or both of these is clogged with accumulated coffee grounds. Try cleaning out both well.
-tony
Apr 28, 2008 | Saeco Easy Espresso Machine
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Magic Comfort Plus Espresso Machine Logo
52 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
