Question about Whirlpool Refrigerators
My whirlpool Model ED5VHEXVQ01 Type 25 MSSA new in 2009 just stopped working last evening - opened the fridge this morning and heat was coming from the fridge side - freezer not working either
  • 66 Answers
SOURCE: whirlpool GD5RHAXNQ SIDE BY SIDE, CHIRPING NOISE WHEN LIGHT IS PLUGGED IN
short in the control panel. or the ground in the control panel is loose.
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool fridge freezer
trying to open door?? does it feel as if top wants to open ad bottom of door is being stuck shut? or mabye a package of frozen food has shifted of a shelf and is holding the door shut, if so brute force will solve that one.if it feels like held at bottom sounds as if youmight have a clogged defrost drain tube.drain water backing up onto freezer plor and holding door shut. even then forcing door open is only way then removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over.
Posted on Mar 01, 2008
  • 184 Answers
SOURCE: BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Posted on Apr 08, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Posted on Apr 19, 2010
Testimonial: "Thanks very much for your help, really appreciate it "
I have a whirlpool refrigerator. The refrigerator is not cooling and there is condensation everywhere. Why is this happening and what do I do about it?
check that the door is sealing properly. condensation is an indication that warm air is getting in somewhere. check the door seal and alignment of the door.
Sep 30, 2016 | Whirlpool Refrigerators
I have a whirlpool 25 mssa And makes ice but not to much ice. How can I fix it?
So you are saying that the ice maker has not been producing ice like before correct? Are the Ice Cube's different in size or there anything different about the way they look or is it just there's a difference in volume suddenly? Can you give me a temperature of the freezer near the ice maker it should be at 5 degrees or below to properly operate ice production. Is there ice build up in the opening where the water comes in to fill the ice maker ?
Appliance 911 Sea Breeze
Sep 08, 2016 | Whirlpool Refrigerators
I just got a brand new whirlpool fridge 25 MSSA model #WRS325FDAB02 only 6 months old, and the ice dispenser and the shoot are leaking even when locked, and it's not producing ice the way it did when we...
Check the dispenser door itself, is it closing? If not find out why? If a part needs to be replace than warranty will cover it, if the door is obstructed with ice they could charge you. I wouldn't but warranty does cover anything but part replacement item anymore. Customer instructs are not covered. Is all the doors closing completely and sealing? Now is the frost just frost or clear ice? Frost means warm air mixed with cold air, so ice means water froze. There is a difference between the two. Get back to me if you have more questions or concerns, would be happy to assist you
Jul 31, 2014 | Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
Hello: Our Kenmore Coldspot refrigerator (side by side )/Type 25 MSSA is barely cooling on the freezer side and NOT cooling on the fridge side so all of our perishables are going to waste. The...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 13, 2011 | Refrigerators
I bought by 25 MSSA, Model ED5vHEXV001 at Lowes less than a year ago. I travel for extended periods of time an unplug the frig., open the doors. When I returned recently the frig compressor would not...
Could be a relay switch, needs to be troubleshooted to find out problem, but if under one year old it is still under warranty. Call lowes they will get a service tech out to repair it for you.
Aug 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Feb 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
