Question about Daewoo DTQ-14U5SC 14" TV
Lines vertical vertical line on daewoo tv 14"
    Top Expert:
  • Daewoo Master
  • 74,251 Answers
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 22, 2013
Vertical line on daewoo tv 14"
If that is an LCD screen, you need a new one. The edge connection on the LCD has come loose at one solder point. You could take it apart and see if you can locate it.
Oct 21, 2013 | Daewoo Cars & Trucks
Daewoo dtq-206sc have retrace lines
if retrace lines at top of picture the issue is in the vertical circuit--usually a bad filter cap and or the output chip (most of the caps that cause that are 220 uf or 330 uf and connected directly to one pin on the chip.
If retrace lines are across entire screen---likely the master screen control on the Flyback is set too high--causes excessive brightness and the retrace lines.
May 22, 2012 | Daewoo DTQ-20U6SC 20" TV
2004 rear projection daewoo tv problems
No value used, no one wants this old technology anymore.
May 18, 2017 | Daewoo DSJ-5510CRA 55" Rear Projection...
White line only, has sound, may be 14 yrs old.
Hello
If there is a white line across the screen, the vertical output section of your TV is faulty. If the line is vertical at the middle of the screen, horizontal deflection yoke doesn't get sweep signal. You haven't mentioned about the full mode number of your RCA TV. Therefore I can only give you this much hint. OK.
Mar 06, 2011 | RCA Televison & Video
Screen showing three vertical black lines
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 02, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No vertical deflection, just a line in the center. I don´t have the diagram. Tanks
Look up for faulty Elkos in the vertical Stage near the powersuply abd then find the Vertical IC with are fit near by the highvoltagetransitor
Sep 05, 2009 | Daewoo DTQ-13P2FC 13" TV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Black vertical line on LCD screen - Help!
Yes.. It's either a Y-board or logic-main board that needs to be replaced and a qualified shop will have no difficulty in determining which one and getting it back on it's feet...
I think you'll be surprised too, that's it's not that expensive, comparatively.
Bill
Nov 19, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DTQ-14U5SC 14" TV Logo
48 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
