I have an older Onkyo DX-2500 CD player that will not open the door to insert a CD. I removed the 4 screws that hold the cover on to see what was going on. When I press the Open Door button on the front the galvanized steel plate tries to come up but apparently not high enough to allow the door to slide out. When I gently press the back of that plate and it engages the door freely opens. If I press the Close Door button it also returns without any issues. I called a service center for Onkyo and they wanted $100 just to look at it. I can't justify the cost on a machine I could replace with a 6 disc player for $175... Any suggestions how to fix ?
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
Onkyo DX-C100 Service Manual
Here is repair manual http://www.givemefile.net/smanuals/cd_dvd_blue-ray_audio_players/onkyo/file/5743.html
Apr 01, 2012 | Audio Players & Recorders
CD jammed in player. Won't open.
Your going to have to take it apart and manually remove the cd.
To do this remove the top cover.
Make sure the power is off and that it is unpluged when doing so.
Mar 28, 2010 | Onkyo DX-C390 6-Disc CD Changer
Open a jammed cd player
you have to take a screw driver and open it .the push it from the inside
Feb 01, 2010 | Onkyo DX-C390 6-Disc CD Changer
Solve a jammed cd problem
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Jan 31, 2010 | Onkyo DX-RD511 CD Player
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-C200 cd player
I have a Onkyo DX-C200 cd player face plate for $25.00. cyberhe@optonline.net
Sep 03, 2007 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
