Question about Saeco Magic Comfort Plus Espresso Machine
Water leaks out the right side near the brew group when making coffee
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Buy new Faemaa .
Posted on Nov 02, 2013
  • 5 Answers
SOURCE: Water leaks during brew cycle
you have a split in or a loose conection where the water pipe conects to the boiler so water comes from there and the lack of pressure is making the machine work harder which makes it sound bad
Posted on Dec 14, 2008
  • 2039 Answers
SOURCE: Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Posted on Jan 11, 2009
EsWorld
  • 1618 Answers
SOURCE: My Vienna Digital suddenly makes weak coffee and it not hot
Try resetting the maching to factory settings.
Here is another question, bear with me, what do you brew the coffee into? And is it pre-warmed?
Posted on Jun 20, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
  • 1089 Answers
SOURCE: son in law added whole beans in ground coffee
The notches should be at 10 and 12 approx. If the noise is a clicking sound you have a broken brew drive, and the gears have to be replaced. The brew unit can't compress whole beans and something has to give.
There are to triangles on the front of the brew unit at the round hole where it piviots. They need to be pointing at each other, if the 2 notches are in the correct position, its ready to install
Posted on Dec 03, 2010
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Water coming from machine when brewing coffee water looks like coffee, brown in color and appears to be coming from brew group area. i have a saeco odea go machine. well maintained
there is excess water that comes from the injector when the brew group disinguages it. make sure the path is clear of coffee grounds in such. Some other things to check are the conditions of thr o-rings there are to 2 on thr injector inside the machine and one on the brew group if there damaged at all they will leak.
Dec 14, 2009 | Coffee Makers & Espresso Machines
Saeco Magic Roma - Steam & Water OK, no Coffee
Remove brew unit and push on bottom end shaft you will hear a snap then turn and lift small bar lever ( if you are holding unit with handle towards you it will be on the right side), this will help you see if there is an obstruction.
Sep 13, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Leak
if you clean your brew unit and coffee lines infrequently you're coffee may taste differently when you do get around to cleaning them.
If you are not happy with the taste, I would receommend the following steps
1. A Good Descale (See our article here for on Descaling your Coffee Machine for details) - This will remove excess mineral build up.
2. Try a Saeco Cleaning Tablet in your brew unit - this will remove excess organic build up (Coffee and Grease)
3. Use only filtered water
4. Rinse your brew unit every time you empty your coffee dreg drawer
That should bring your machine back to optimal coffee making condition. If you are still not happy, try some different coffee blends for a while - a change can be as good as a holiday
Paul from Coffee Shrine
Saeco Coffee Machine
Aug 20, 2008 | Saeco Magic De Luxe Espresso Machine
The grounds are sloshy and the coffee is weak - I think that the coffee is leaking out as the hot water is being pumped through the ground beans
I think I have the answer to this: when mine started doing the same thing, I found that coffee grounds had accumulated and were blocking the seal of the water supply with the brew-group.
The Behind the brew-group is a clear tube with o-rings that slides into the brew group to supply water. One or both of these is clogged with accumulated coffee grounds. Try cleaning out both well.
-tony
Apr 28, 2008 | Saeco Easy Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Coffee has stopped dispensing
Looks like your machine is leaking internally and rather than the water come out of where it is supposed to, it is leaking inside.
Repair Service in New York
http://cerinicoffee.com/Saeco_service.asp
Or check saeco website for a service center near you.
Hope this helps,
Johnny C
Oct 27, 2007 | Saeco Vienna De Luxe Espresso Machine
Water in the coffee grounds drawer
Look for a leak near the brew group on near the piston area.
Changing the brew group should solve this problem.
http://cerinicoffee.com/item.asp?cID=0&PID=206
Johnny C
www.cerinicoffee.om
Oct 01, 2007 | Starbucks Saeco Italia Digital Barista...
Saeco Magic Comfort Plus Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
