Question about Sanyo Televison & Video
Permanent blue light on my sanyo ce32ld90-b lcd tv no picture nothing at all
  • 125 Answers
SOURCE: picture goes off with blue light still on.
It could be some hardware failure. But lets be optimistic. Try to reset your TV-set to the manufacturers default state. Not sure about the exact procedure but it must be fownd in the "menue", somewhere under "Settings" or "Channel search"!
Good Luck
/SciPhinx
Posted on Jul 11, 2009
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
  • 11800 Answers
SOURCE: Sanyo CE32LD47-B LCD TV.
No, the PS has nothing to do with that - the standby light blinks to signal an internal component failure and a bad source connection can't cause that. Since the light is steady at start it means that the power source starts normally but the process doesn't end correctly: the defect is located in either the mainboard (the processor has failed) or the inverter for the backlighting tubes has failed.
To identify which you will need to open the tv and test the voltages on the power source board starting with the output line for the inverter; after that the voltages for the mainboard - you will need at least a good multimeter and experience in electronics repair. If you don't have both then unplug the tv from the mains and call a repairman.
Posted on May 03, 2011
blueextc3221
  • 15935 Answers
SOURCE: sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
Posted on May 27, 2011
caroldon
  • 17130 Answers
SOURCE: Sanyo 46" lcd had half
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Since this fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Posted on Jul 27, 2011
Sanyo dp42841 no picture
Sounds like either the CCFL for your LCD TV has blown (It's basically a miniature florescent tube) or the inverter that drives it has given up.
Have a look on Ebay for replacement parts and to see if you feel confident enough to tackle the job yourself.
Sep 05, 2014 | Sanyo Televison & Video
My LCD Sanyo tv won't show picture and the green
PLEASE CHECK CABAL LINE FIST. SEE THE TV BACK SIDE AND ADJUST UR CABAL JACK.OR HAVE ANY DVD PLAYER PLEASE ADJUST UR DVD JACK SEE UR TV PICTURE.IF SHOW UR PROBLEM SOLVE OR NOT SHOW UR TV PANEL PROBLEM.
Dec 27, 2012 | Televison & Video
Blue light flashing no picture or sound
Sounds like a main board problem, I've worked on quite a few Sanyo's and their main boards are notorious for failures.
Jul 23, 2012 | Sanyo 42 in. LCD TV
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
Hi gud noon.just want some advice i have a problem with our tv sanyo flat screen if we try to turn it on it only appears blue screen theres no picture....thats our problem... we try to call already the...
  1. Try changing the input on the TV to see if the Blue screen goes away. Can you access the TV menu on the screen? If so, try running a channel scan until it is complete. Then check if the blue screen is still there.
  2. Disconnect any RCA cables, or other input cables from the back and see if you still have a blue screen.
Here is the link to Sanyo's Support site: http://us.sanyo.com/Customer-Support
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Feb 25, 2011 | Sanyo DP32648 32 in. LCD TV
I got a new Sanyo Vizion 46" LCD tv as a present about 2 weeks ago. I noticed since the first day when I change channels I can still see some images of the previous channel I was watching. Should I...
Return the tv for another one for the replacement.This tv have a problems,call a delay prograssive scan.That why u see the jet trails of the previous pictures.This problems,will not go away,but will getting worse and even might have a permanent pictures screen burn of the previous pictures in LCD screen panel too.
Nov 29, 2010 | Sanyo DP46849 46 in. HDTV
Sanyo tv when switch on has a blue box with
my sanyo tele isnt switching on, there is a white light flashing, but nothing is switching on?
Jan 02, 2010 | Sanyo Televison & Video
No picture, no sound.
contact sanyo, sounds like your display panel has gone bad
Sep 08, 2009 | Sanyo DS31590 31" TV
Sound but No Picture
Connect your outdoor antenna directly to your antenna in, in your TV see if it works and do the same with your cable input if it works then the A/B box is at fault.
Oct 28, 2007 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
82 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
