Question about Exercise & Fitness
The speed sensor of my TX400 treadmill touches the pulley wheel.
    Top Expert:
  • 12,223 Answers
See the diagram attached. and fix it. God bless you
The speed sensor of my TX400 treadmill touches the - 4b56971e-b071-466f-850b-21fdf86c42aa.gif
Posted on Oct 22, 2013
2 Suggested Answers
SOURCE: Can I fix my Sportcraft TX400 Treadmill ?
adjusting the belt
Posted on Jun 19, 2010
TX 5.0 RC just stopped a # 3 came on the screen. After reading several posts we looked at a wheel within the motor compartment(not the wheel with the belt, it's the wheel to the left if your looking...
Info from PDF files located on Sportcrafts website under manuals.
E3 - No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don't tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Also:
Use an epoxy to glue it. It is a plastic that is difficult to adhere to.
Jan 22, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Speed sensor error will show on the dispaly and comes to a stop
ADJUST THE SPEED SENSOR:
Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
ADJUST TOO: 1/8" THE SENSOR SWITCH SEE THE DIAGRAM.
11_29_2011_3_41_23_pm.gif11_29_2011_3_41_40_pm.gifSee the block diagram for any treadmills. how the main controller board has the aprox 90% of function. You must finally test the Main C.B.
Sincerely.
E.CUADRA
Nov 29, 2011 | Tunturi T60 Folding Treadmill
Start at full speed then stops
If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
Nov 28, 2011 | Epic View 550 Treadmill
Pace master error 1.0
1) probably a faulty speed sensor
2)the speed sensor is not plugged in properly.
3)possibly a faulty motor control board or lower board.
4)Motor Faulty.
5)Transformer Faulty
The error codes will differ between makes and models but could be e1.
Here is how to adjust the speed sensor:
a)Make sure the sensor is as close as possible to the pulley without touching it.
b) make sure the sensor
is aligned with the magnet.
c)There is a screw that
holds the sensor in place that needs to be loosened to adjust the sensor.
d)Re-tighten the screw
See the attached diagram that I did ,and Watch how the90% of function of the treadmill is coming Main Controller Board
Nov 25, 2011 | Exercise & Fitness
Nordic track treadmill stuck on highest speed
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 09, 2011 | Nordic Track NordicTrack Commercial 1500...
Nordic track treadmill stuck onfull speed
GOOD LUCK.SINCERELY
Where is the speed sensor connection for a blade z
their is two place any of the treadmill either on the frame by the front roller/ pulley or on the motor itself by the fly wheel or the opposite end.
May 13, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Track will only turn for a few seconds when turned on and then quit
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
Feb 19, 2010 | Proform Exercise & Fitness
TX 4.9 sportcraft treadmill
Aug 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
