Question about Can You Imagine Laser Stars By Can You Imagine
How to repair a Can You Imagine Laser repair
I need to know where to find a replacement ty-50b motor for a can you imagine laser stars
The motor ratings are also required to help you , if it is a custom made motor then you have to obtain it from the equipment manufacturer
Jun 21, 2015 | Laser Office Equipment & Supplies
Would it be like a new player,to have the laser lens replaced.How good are they after thatAre they like new.Mine is in like new shape now.Thanks for your time.
depends on the brand/model. Most dvd players do not get just the laser replaced anymore. You actually replace the laser/sled motor/turntable motor assembly.
Apr 07, 2015 | Televison & Video
My Kyocera Mita KM-KM 1635 vari laght how to dark
1. you should service copier
2.replace imagine unit
3.replace toner
4.Clean LS U(Laser unit)
I hope fix problem
Jul 13, 2012 | Office Equipment & Supplies
I have a Philips CDR 778 audio cd recorder. I try
you prbly need to replace the burning laser which i would imagine is still avail however the cost of the laser may not b a prblm but fitting it could b
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
Reset imagine unit samsung r350a
sansung clp350 have toner chip that chip can reset easy. you need resetter we provide you also.
www.chipresetters.com
email: pateltraders@gmail.com
Jayendra Patel - +919825523201
msn:howtorefill@hotmail.com
Feb 18, 2010 | Samsung CLP-350N Laser Printer
I send or try to copy a document on the 8180c printer, it sets out the paper, but there is no image on the paper
If this was the case all the time, I would imagine you have an incorrect driver in the Laser Printer. You should be able to upgrade the drivers by contacting the the Canon Co.
If this is a new problem the static bar that runs across the drum has lost it's positive charge to produce the picture should be replaced ... its not cheap !
Jun 19, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Color background, and then C255X error code (x depends of the color imaging unit)
Those codes are related to an abnormal toner to carrier ratio. If you are getting multiple errors that could be a control board failure. I will consult Konica Minolta Solutions and post futher as the information becomes available.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Can You Imagine Laser Stars By Can You Imagine Logo
Top Can You Imagine Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Can You Imagine Toy Expert? Answer questions, earn points and help others
