Question about Onkyo DX-C390 6-Disc CD Changer
I have a DX-2500 CD player and the door will not open ... I removed the 4 cover screws and can se the plate trying to engage but will NOT come up high enough to open the door. If I gently depress the back of the plate down far enough the door opens and will close when pressing the Open/Close button. Is this something I can fix on own???
You need to replace your cd or else you buy n lng....
Posted on Oct 22, 2013
SOURCE: Open & close button Does not work
Being that it is an old unit, even though it worked just fine except I had to open and close the drawer by hand. I sent it to the trash bend, It was an Onkyo C110. Thanks anyway!....Bob
Posted on Nov 20, 2008
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Posted on Mar 04, 2009
  • 211 Answers
SOURCE: Onkyo DX-703 CD tray engine tries to oepn but
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Posted on Jan 14, 2010
rockmeister
  • 2047 Answers
SOURCE: it is a 3 cd
Fixing slide racks are usually considerably affordable to fix. This is so because the mechanism which controls the rack is usually made up of various components and fixing it usually entails just the replacement of only a few of those components and most time usually it is the propeller which need replacement.And in some rare cases one of the pulley teeth.
Hope this solution has been helpful?
Posted on Feb 05, 2011
SuperTech-11
  • 1591 Answers
SOURCE: Drive belt replacement to open and close cd drawer
I have no idea where you are located, but I know this guy has belts for everything, you just need to know the size (or he can look it up).
UNIVERSAL AUDIO VIDEO ELECTRONICS
1137A QUEEN STREET EAST
M4M 1K9 Toronto, ON
Phone: 1-416-461-9899
Posted on Mar 01, 2011
I need to replace door seal on this machine but i dont know how to remove the front of the machine i have the top cover off
If it is Whirlpool / Maytag try parts diagrams at
www.whirlpoolparts.ca
Normal procedure to open front door panel on a front load.
1. Remove top cover.
2. Remove Control panel.
3. Remove bottom kick plate cover
4. You will see the door panel screws. Two on top corners and two on bottom corner.
5. Keep in mind, you have to remove the door lock (latch) from door panel before removing door panel.
Apr 25, 2015 | Washing Machines
Onkyo DX-C100 Service Manual
Here is repair manual http://www.givemefile.net/smanuals/cd_dvd_blue-ray_audio_players/onkyo/file/5743.html
Apr 01, 2012 | Audio Players & Recorders
Our back door (double glazed with locks at top, middle and bottom) has become permanently locked from the inside. It would appear that the lock at the top has bolted shut. (We have safestyle doors and...
Hi, W/D here.
Easy fix. Your upper locking bar has slipped. While someone is holding the door handle in the open position, you'll need to push the upper lock bolt back far enough to get the door open. You can slide it back carefully with a screwdriver or knife, a little at a time, while holding slight tension on the door with the handle. OK, door's open. Remove the inner door lock cover plate. The lever and locking knob will come off with it. Remove the mortise cover plate, on the edge of the door. Insert a small, thin bladed into the upper alignment slot in the lock behind the mortise cover plate, and loosen the upper allen screw behind the inside lock cover plate. Use the screwdriver to engage a slot in the locking bar, and raise or lower the bar until you have it level with the alignment slot. Tighten the allen screw.
Sometimes, the bar is so far out of alignment that you will have to gain access to the other end of the bar, in order to raise or lower it. This is done by removing the plastic cover on top of the door, and using needle nosed pliers to move the bar.
This should fix you up.
Best regards, --W/D--
Jan 28, 2011 | Locks & Locksmithing
How do you remove am/fm cd player from 2005 ford focus
There is a plastic "plate" surrounding your CD player; on the back of this "plate" there are 4 plastic guide/retainer pins about 3/4 of an inch long. Generally located in the 4 corners of the "plate." With that in mind, using a taped-up, flat-headed screw driver(tape the flat end as to not scratch the interior trim) and simply and ever so lightly, pry the coin dish(below the "plate" mentioned above)out and away from the dash,opening a hand sizes hole. From that hole using the same screw-driver, using the same technique, remove the plate; being oh so careful because the temp control knobs, cig lighter, etc, come out attached to the "plate."
You will notice, I believe, 4 small octagonal plastic bolt heads protruding from the area right next to the player......remove those bolts, unplug radio and whalll-laah..
Apr 03, 2010 | 2005 Ford Focus
Solve a jammed cd problem
Usually if you remove the cover you can access the area where the CDs are. You may have to remove the cover from the drive also. Let me know how this works out.
hardrocko
Jan 31, 2010 | Onkyo DX-RD511 CD Player
How do I remove the door panel and replace the inside door handle
PLEASE DON'T FORGET TO RATE!!
Door Panel
  1. Remove the door handles and the locking knob from the inside of the doors.
If equipped with screw retained door pull handles, remove the screws through the handle into the door inner panel.
  1. If equipped with remote control mirrors, remove the remote mirror escutcheon, then disengage the end of the mirror control cable from the escutcheon.
Door lock remote control handle
Removing the clip from inside the door handle
3. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switches and the cigar lighter (if equipped) from the electrical harness.
4. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
View of the armrest switch cover plate and remove mirror cable attachment
  1. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
If equipped with electric switches in the door trim panel, disengage the electrical connectors from the switch assembly.
  1. Along the upper edge of the lower trim panel, remove the mounting screws. At the lower edge of the panel, insert tool No. BT-7323A between the inner panel and the trim panel, then disengage the retaining clips from around the outer perimeter. To remove the lower panel, push the panel down and outward to disengage it from the door.
If equipped with courtesy lights, disconnect the wiring harness.
  1. If equipped with an insulator pad glued to the door inner panel, remove the pad (with a putty knife) by separating it from the inner panel.
To install:
If replacing the inner pad to the door inner panel, use 3M General Trim Adhesive No. 8080, glue it to the panel.
  1. If removed, glue a new inner pad to the door inner panel.
If equipped with courtesy lights, connect the wiring harness.
Exploded view of the window regulator handle
Exploded view of the door trim panel
  1. Engage the retaining clips around the edge of the lower trim panel, then install mounting screws.
If equipped with electric switches in the door trim panel, engage the electrical connectors to the switch assembly.
  1. If equipped with two-piece trim panels, engage the retainer clips to the front and the rear of the upper trim panel.
  2. If equipped with an integral armrest, install the retaining screws.
  3. If equipped with a switch cover plate in the door armrest, engage the switches and cigar lighter (if equipped) harness connectors, then install the cover plate and secure using the plate screws.
  4. If equipped with remote control mirrors, engage the control cable, then install the remote mirror escutcheon.
If equipped, install the pull handle screws through the handle into the door inner panel.
  1. Install the door handles and the locking knob to the inside of the doors.
Exploded view of the 2-piece door trim
  1. If equipped with a switch cover plate in the door armrest, remove the cover plate screws, then disconnect the switch
  1. If equipped with an integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. If equipped with an armrest applied after the door trim installation, remove the armrest-to-inner panel screws.
  2. If equipped with two-piece trim panels, disengage the retainer clips from the front and the rear of the upper trim panel, using tool No. BT-7323A, then lift the upper door trim and slide it slightly rearward to disengage it from the door inner panel at the beltline.
To install:
  3. If equipped with a switch cover plate in the door armrest, engage the switch harness connector, then install the cover plate and secure using the plate screws.
Nov 16, 2009 | 1987 Chevrolet Monte Carlo
Cabin filter
1 Tools needed are a Phillips screwdriver and a socket wrench. Open door to passenger side of vehicle. 2 Under the glove compartment is a kick plate cover held in place by four screws. Remove the screws and take off cover. 3 The door to the cabin filter is now visible. Remove screw in door and unhinge. 4 Remove the first filter by pulling straight down. Remove the second filter by sliding forward and pulling down. Replace with clean cabin filters. Reattach door and kick plate cover.
Good luck and hope this helps.
Jun 26, 2009 | 2004 Toyota Avalon
A dvd is stuck in my Chrysler town and country multi disk dvd/ cd player. How do I remove it?
Look around the face plate for a very small hole...use a straightened paperclip or equivalent and press in a few inches...its a manuel door release and you should gain access to at least the loading tray.
Apr 24, 2009 | 2005 Chrysler Town & Country
CD is stuck in the Numark CDX cd turntable
hello, there should 4 little black screws on the top of the cd tray when it is removed from the deck. two of them are on the rear top in black plastic. the other two are holding the silver plate down as well. remove those four screws. the top should slide off. after that is off, you should be able to see how the disc is being secured. careful not to pry any thing it should all come apart. good luck.
Nov 29, 2007 | Nu Mark Numark Cdx Table Top CD Player CD...
Onkyo DX-C200 cd player
I have a Onkyo DX-C200 cd player face plate for $25.00. cyberhe@optonline.net
Sep 03, 2007 | Audio Players & Recorders
Onkyo DX-C390 6-Disc CD Changer Logo
145 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
