Spl p100 manual
CALCULATOR ROUNDS UP TO THE NEX NUMBER, I NEED DECIMLAS. HOW CAN I GET IT TO PRINT THE RESULT WITH DECIMALS?
  • 7,993 Answers
I do not have access to a manual but from pictures I saw, I believe it is the key marked 4/5 that sets the round off.
Posted on Oct 22, 2013
2 Suggested Answers
SOURCE: change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Posted on Aug 06, 2010
How to stop it from rounding up or down
Did you try it on the "F" position?
Good luck,
Paul
Oct 03, 2016 | Staples SPL-P100 Printing Calculator
Why are totals rounding off
In the product details of this calculator, it states that there is a "decimal point selector." This is normally a slider starting with the letter F followed by the numbers 0123 etc. It is probably on 0. You can set the number of decimals to whatever you want, or use F for full numbers. For example, if you set this to 2, you should always get 2 decimals.
Good luck,
Paul
Apr 07, 2016 | Staples SPL-P100 Printing Calculator
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
Change decimal placement on calculator
Jun 22, 2010 | Office Equipment & Supplies
Sharp ELSIMATE EL-240SA - how do you stop this calculator from rounding up to whole numbers? I generally need two decimal places. Gordon Gillies
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Jul 06, 2009 | Sharp Office Equipment & Supplies
SPL-P100 calculator problem
There is a tab button that controls the amount of decimal places you would like. press tab and it will change to 0-2-3-4-A-F showing on the bottom of the screen.
It works. :-)
Joe Stogrin
www.littlejoesauctions.com
Jun 12, 2008 | Canon P23-DH Calculator
887 people viewed this question
k24674
