Question about Honeywell TH5320C1002 FocusPRO Non-Programmable Communicating Thermostat
I have the heat on, but cool air is coming out
    New Friend:
  • 50 Answers
Filament wronout
Posted on Oct 22, 2013
Heat coming out when in cool mode.. got new thermostat same thing. American Standard XL 624
Does it cool when in heat? Is this a heat pump? What's supply air temp vs. return air temp? Outdoor unit running?
Mar 26, 2018 | American Standard Heating & Cooling
LG air conditioner the fan comes on when in heat mode but when switched to cool the fan stops
They run on different speeds for heat and cool you either lost a speed for cool or the relay for the cool mode is not closing, Does the compressor come on in cool mode?
Sep 05, 2014 | LG Heating & Cooling
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
Apr 15, 2017 | Honeywell Heating & Cooling
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
Heat is not working. Just blowing cold air no matter the setting
is the "cold air" just room temperature air. put it on cooling and see if its colder than the air that is coming out of it when its on heating leave it on for a few mins make sure its cooling to.. it could be the reversing valve not pulling it onto heating if it can cool and not heat.
if its not cooling or heating it could be a few different problems. gas leak ,pcb boards ect.
Nov 09, 2010 | Amana PTH123B35AE Air Conditioner
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Apr 29, 2010 | LG Art Cool LA181CNW Split System Air...
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Heated air coming out when unit is in Cool Mode
Heat pumps are sometime constructed to "Fail in the heat mode." It could be either the t'stat or the reversing valve. Be sure the t'stat is wired correctly. Usually the"O" terminal is for the reversing valve on the outdoor unit.
Mar 28, 2009 | Heating & Cooling
Honeywell TH5320C1002 FocusPRO Non-Programmable Communicating Thermostat Logo
80 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
