Question about John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor
Where are the transmission drain plugs on a john deere 2020 tractor
    Problem Solver:
  • 23 Answers
It is located on the bottom of the transmission reservoir, and that is 1 foot to the right from the battery.
Posted on Oct 21, 2013
mattofilms
  • 110 Answers
SOURCE: 2020 john deere diesel tractor with j-d 36# loader
Sounds like you need more hydraulic oil - Or like you said the transmission screen (dirty).
Where it is ??
Posted on Jul 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Compression in a 1966 john deere tractor its a 2020
is this a multi cylinder diesel farm tractor or what
remember that questions go global and you have to be specific in details as a jd unit 202 in your country may be a 1212 or what ever in another country
however moving on , if it has more than 2 cylinders , the problem can be a head gasket blown between adjacent cylinders , cracked head or valve problem ( burnt or incorrect valve adjustment)
same ideas apply to petrol engines as well
Dec 15, 2015 | John Deere Garden
How do i set timing gears for a john deere 2020
I'd suggest going to John Deere's website and look up an owner's manual and repair manual . If you have Adobe Reader you can copy it in a PDF format.
May 12, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Where is the drain plug for the transmission on the john deere 4210 tractor
There should be a pipe type plug in the bottom of the transmission housing near the draw bar inline with the rear axle housings. Whether you have a hydrostatic drive or gear drive, the plug is in the same place. Reference # six in drawing.
Feb 16, 2011 | John Deere Seat 4210 4310 4410 4510 4610...
I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Where it is ??
Mar 27, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere Seat 4210 4310 4410 4510 4610 4710 Tractor Logo
144 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
