Question about Sewing Machines
Singer prelude 8280, entire bobbin case came out in two pieces. I don't know how to put it back in.
  • 130 Answers
Refer online on utube on 'singer installing a front loading bobbin case threading & insertion'
Posted on Nov 01, 2013
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 27 Answers
SOURCE: type of bobbin
15 class bobbins
Posted on Jan 10, 2009
RickE1
  • 202 Answers
SOURCE: i dont know how to thread a bobbin on a singer prelude 8280-help!
Look it up at www.sewusa.com threading diagrams.
Rick
Posted on Aug 03, 2009
  • 12 Answers
SOURCE: how do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Posted on Aug 20, 2009
  • 1788 Answers
SOURCE: how can I download a user manual for a singer
Go to www.singerco.com and download a free manual under customer support. Save it to your computer and then you never have to worry about misplacing it. Happy New Year and happy sewing.
Posted on Jan 03, 2011
Singer Prelude 8280 Sewing Machine stuck
Is the knob on the side, where you loosen the needle to rewind the bobbin, tightened? Also, there may be some threads in the bobbin case messing things up. Unplug the machine if you are checking the bobbin case.
Apr 18, 2013 | Singer 8280 Mechanical Sewing Machine
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
It is in your top threading, try this test, rethread, now with the presser foot up, pull the top thread, it should feed smoothly, now lower the presser foot, it should barely move. Sometimes this seats the thread in the tension discs. Also, make sure that your needle is fresh.
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
How to thread bobbin
Go to www.singerco.com and under customer support and click on manuals, put 8280 in box and download your manual for free. Save it to your computer and you will always one on hand.
You have a vertical bobbin you have to put the bobbin in the case and pull the thread through the guide. and you must insert it right, with the finger facing up. It is much easier to look at your manual to see this, because explaining it is very difficult because we do not know what you are doing.
Sep 28, 2010 | Singer 8280 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
