Question about Refrigerators
Admiral designer series
I have a small refrigerator and I need a new gasket that measures 18 by 31. How do I get a new one?
  • Refrigerators Master
  • 17,164 Answers
What is the model number?
Posted on Oct 21, 2013
5 Suggested Answers
  • 219 Answers
SOURCE: admiral designer series ice maker
replace your watervalve
Posted on Mar 19, 2009
SOURCE: need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
http://www.repairclinic.com/Appliance-Parts?s=t-HMG211380-%3d%3dc270
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
Posted on May 02, 2009
caroldon
  • 17130 Answers
SOURCE: I need to replace the
These gaskets are press fitted on to the slot as the sealing gasket.
So procure the orginal part fromt he dealer for the size,remove by using a blunt screw driver, clean off the grooves all along the door, then place the head tip of the gasket and push into the slot.
The end should be made to merge correctly before it is cut.
Posted on Sep 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have an Admiral designer
There are 3 models of this unit:
HMG651580
HMG651581
HMG651587
That does not matter for hooking up water. Look on the back of the unit. You should see a 1/4 inch copper tube sticking out with a black rubber cap. Pull off the cap and connect your water supply using an icemaker connection kit available at any hardware. Most kits come with instuctions but it really rather simple. The key is to ensure there are no leaks at the saddle valve or compression fittings when your finished.
If you do not see a copper tube sticking out... carefully remove first the right side of the lower rear fiberboard cover and look for a water valve connection. It is usually on the rt side but since this unit is actually made by Sharp... I am not sure. Check both sides.
The
See this net search:
http://www.google.com/search?q=ice%20maker%20connection%20kit&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi
The kits run from around $10.00 for the plastic line kits and up to $35.00 for the copper line kits.
All kits use compression fittings and saddle valves for making the water connections. It is recommeded that you also install an external in line water filter even if your refrigerator has an internal filter. The external filters are dirt cheap compared to the internal filters and will make the internal filters last 5 - 6 times longer.
Thanks for choosing FixYa,
Kelly
Posted on Jun 02, 2011
I have the admiral designer series HMG21149 refrigerator and I need the glass that goes on the bottom shelf over the veggie and fruit trays.
go to the service dealer spares for one
if it is no longer available go to appliance repair shops and ask if there is one from a fridge unit going to the dump
Jun 22, 2016 | Admiral Refrigerators
I need to know the cubic feet of my Admiral refrigerator model #CNS22V8 serial #KT39003573 Thank you
The details are not available online. Measure it yourself. Measure (in feet to nearest 3") width and multiply by depth, and then multiply that by the height.
1 foot 3" is 1.25
1 Foot 6" is 1.5
1 Foot 9" is 1.75
1.75 x 1.5 x 4 is 10.5 cu ft
May 15, 2016 | Admiral Refrigerators
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Apr 08, 2015 | Admiral Refrigerators
I have a admiral fridge designer series # HMG 62186 that I purchased in 1997. It has always had popping sounds and sparks behind the drawer in the freezer. A repairman told me this was normal, so I...
Hello WIntersno,
I understand that your refrigerator is sparking behind the freezer drawer and you would like to know if this is a fire hazard. In my opinion it would be a fire hazard as plastic and rubber is flammable and the repairman is not true in saying that this is normal. A refrigerator should never spark as this is also an electrical hazard. I would suggest having another repaid man come out and fix the problem or purchase a new box.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Admiral Refrigerators
I need to replace the door gasket on my old Admiral refrigerator, model # C1042L. Can you help me? Thank you very much. Sincerely, Charles Seidel
Sep 14, 2010 | Admiral Refrigerators
My admiral designer series stove is showing a F 1
f-1 usuqally meens a stuck key pad.sometimes if you unplug it for a wile it may reset other than that you need to replace the clock/touchpad.
Mar 08, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Need top shelf for admiral refrigerator
May 02, 2009 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
