Question about Microwave Ovens
Replacing light bulb cover in swan sm2989 microwave
  • 16,994 Answers
Do you need the part or the how to guide?
Posted on Oct 21, 2013
  • 27 Answers
SOURCE: Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Posted on Jun 26, 2007
  • 135 Answers
SOURCE: Light bulb replacement in a Tappan Microwave
Hi Mike.
Difficult to say on yours. You may try the following. On the back or side, if there is a little cover that's screwed into the panel. Otherwise browse around on the inside. Be sure to unplug the micro before checking. Once found be sure to replace with a microwave lamp and not a fridge lamp. There is a difference. Good Luck,JUS004
Posted on Feb 29, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave bulb
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
  • 2692 Answers
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Posted on Dec 31, 2008
SOURCE: amana AMV5206AAQ light on the bottom of the microwave out
I received an email telling me to pull the bulb straight out of the socket. Sometimes they can be hard
to pull out. It worked, I appreciate it.
Thanks, Carl
Posted on May 08, 2009
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Replace oven light bulb in FMV 156D
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
Oct 11, 2012 | Frigidaire FMV156DC Microwave Oven
How to replace burned out light bulb
You need to remove the top cover to access the bulb. That is the only way on most microwaves.
Dec 02, 2011 | Emerson MW8107WA Microwave Oven
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave bulb
Jul 05, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
