Question about Car Audio & Video
Bmw 530i 2005(removed radio+aftermarket sub/amp/speakers/equlaizer)engine noise
  • 56 Answers
You are getting feedback noise from the alternator, normally this is not an issue because you used the stock power wires for your new install. I am thinking you routed new wires to an unprotected power source on the car. One possible solution is to install an RF filter on the power line going to your components.
Posted on Oct 21, 2013
SOURCE: low level noise causing sub flutter
Power wires and sound cables running close together can cause this problem. Separate them.
Posted on Dec 09, 2007
  • 14 Answers
SOURCE: speaker Problems
What are the outputs on the back of your stereo? & how are the front speakers wired up, to one of the amps or directly to the head unit?
If you have both amps just feeding the subs & the front speakers connected to the stereo then there should be a setting somewhere that allows you to do this. Have a look on the stereo, some have a switch on the back so that you use one or both internal amp for small speakers & the output for amps.
Posted on Dec 28, 2007
SOURCE: subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Posted on Jan 26, 2009
  • 979 Answers
SOURCE: My speakers do not work but my subs do.
Good day sir, hi, there reason why speakers don't work could either be the folowing:
  1. you speaker voice coil is burnt, to test, you need to get the door speakers out and locate the terminals, prepare a 1.5 double AA battery, use this to test you speaker. connect a wire from the negative of the battery to the negative of the speaker, and the positive battery to the positive terminal of the speaker with a series of gentle taps, you should hear clicking sound. if not replace the speaker.
a9b085b.gif Do it on the other door speaker.
2. check your speaker line from the amplifier to the door speaker.
3. check your power amplifier for loose and improper connection.
4. check your power amplifier itself. Thats it.
Its a little work, visit your local electronic repair shop if your speaker still won't work.
Posted on Oct 09, 2009
drifterK
  • 4924 Answers
SOURCE: I have a 2005 nissan
take a look in the back of the Bose..cause most have a separate exit for the amp of the sub ...with RCI plugs ..and will not affect the normal left right exit for the regular speakers...all you need it is an amplifier for the woofer cause those exits I dont think are amplified...and it will react to the volume from the Bose ...
http://carstereohelp.net/wireharness_Nissan1.htm
here you have some sound harness scheme ..just in case you do not have the extra exit for sub-woofer on the stereo...
Posted on Aug 29, 2010
I have a 95 bmw e34 530i an can't find a wire digram can anyone else me trying to hook up a aftermarket radio ?
you should be able to purchase a ready made loom for this very purpose , google the car ,model, radio loom , should find it
Oct 27, 2014 | Cars & Trucks
Why my radio turns on and off
when my BMW ash trays are full , i buy a new car.
LOL
1: bad fuse, (loose or cracked)
2: bad radio wires connections.
3; bad radio. (we bench test the radio to prove that)
May 04, 2014 | 2005 BMW 530i Touring
Aftermarket amp in a 2011 bmw not getting power
replace the fuse and make sure that your remote turn on lead has not become disconnected.
Mar 06, 2014 | JVC Car Audio & Video
I can hear engine humming in my car radio. It is factory.
If the speakers and subs are factory then it is likely a burnt diode in the alternator. If aftermarket AMP was added it is likely a ground isolation issue.
Feb 23, 2011 | Car Audio & Video
My 2005 accord's radio will power on, but nothing is coming out of the speakers. at one point the speakers would produce a sound and then cut off and even after having this problem was able to turn off...
If you remove the radio, you could check the speaker wires with an ohmmeter to see if any of the wires are shorted to chassis ground. If they are not, the radio is the problem.
Sep 14, 2017 | 2005 Honda Accord
Adding line out inputs for RCA cables to amp
Hello ssmotorcity,
Here's a link to modifiedlife's Durango page showing the wire colors.
http://www.modifiedlife.com/2005-dodge-durango-car-radio-stereo-audio-wiring-diagram/
If you are adding a LOC for an amp to drive a sub, you are probably better off using the rear speaker wires, the last four wires shown on the listing. If you are adding an amp to drive all 4 channels, then of course, you need to convert both fronts and rears. The simple method is to tap directly into the appropriate wires and connect them to the line converter. If you do not want to tap the wires, you can purchase aftermarket wiring harnesses that are made to plug directly into your vehicle radio and/or the vehicle wiring harness. The Metra part number for a stock radio harness is 71-6502. It plugs into the radio and provides pigtail connections for power and speakers. There is, of course, a harness that plugs into the vehicle harness itself, allowing you to make the connections without any cutting or tapping of the original wiring.
Hope this helps.
Apr 16, 2009 | Car Audio & Video
Front Speakers And Stock Sub Stop Working HelP!!!
do you need all this noise whilst driving the car,could you hear an emergency vehicle ??check the fuses first and connections ,try speakers direct to radio
Nov 11, 2008 | 2005 Nissan Sentra
530i 2002 radio
hello mate
there are fuses in the glove box,
open glove box and look to the roof of it, you should see two white latches, turn them and it will fall down and you will be able to see the fuses...
Oct 21, 2008 | 2005 BMW 3 Series
2002 bmw 530i starting problem
2002 530i radio i cant turn on
i press the botton and nothing hapen i look the fuses on the trunk and the are fine is other suses some place else please advice
Jun 25, 2008 | 2005 BMW 3 Series
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
