A newly painted wall looks splochy, shinny in some spots and dull in others.
  • 56 Answers
Most likely due to some texture or old paint or paper on the wall before you painted it. In most cases it is best to prime any wall you are about to paint with Kilz, or some other primer so the application is uniform. Also make sure the paint you are using is well shaken before opening.
Posted on Oct 21, 2013
  • Computers & ... Master
  • 16,038 Answers
I would hope that you had the paint mixed well before putting it on and that the entire wall was done in one event. Also it would be of help to have primed the existing paint first.
Why are the leaves on my Zz plant look so dull an not shinny
lack of / excessive water
poor soil
disease
lack of /excessive sunshine
incorrect Ph value of the soil
talk with a nursery to get a proper idea of the fault
Aug 10, 2017 | Garden
Can you use ultra white paint as a primer on a wall before painting it?
Not recommended, especially if the ultra white paint is anything but "flat." Primer is designed specifically to adhere to other paints. Look into KILZ primer (if it is available where you are), as I have found it to provide excellent coverage for color changes.
May 08, 2015 | Tools & Hardware - Others
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
How do I fix paint chips on the hood?
I suggest you keep touching in the spots and building up the level over time until it is slightly proud of the surrounding paintwork. When fully hardened the surface of the spot should be flatted with a small block. I use the end of a short piece of 3/8 or 1/2 inch wooden dowel with a circle of fine abrasive paper glued to it. I sand wet and begin with 600 grit and finish with 1000 or 1200 grit. Once the area is flush it can then be polished with a polishing compound such as farecla and finished with T-cut.
A coat or two of lacquer can be applied or a few coats of hard wax polish.
May 07, 2017 | Toyota RAV4 Cars & Trucks
Printer creates horizontal lines across paper that are either blank (no ink) or skipping/sliding looking blurring and distorting the text in that spot. This has been going on for a month. Changing...
The print-head is like a paint-brush -- brush sideways across a white-coloured wall, and you should get a wide "band" of paint. If only half of the paint-brush has paint on it, then only half of that "band" on the wall will get painted, leaving a horizontal strip of white showing through.
So, launch the Canon software that is installed on your computer, and run a few "print-head-cleaning" cycles, to unclog those ink-jets that are _NOT_ shooting the ink onto the paper.
May 20, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Remote wont work unless it gets struck
Check your battery contacts in the remote . look for sighns of leaking batteries , the terminals may be dull and should be shinny. Clean with cotton bud and wd40 (switch cleaner) emery cloth .
Also change the batteries and make sure the contacts are tight against the batteries
Jun 01, 2010 | Televison & Video
I have a deep scratch in one of my doors on my Buick. I bought the touch up paint but I'm not exactly sure how to apply it. I have used touch up paint many other times with many cars and it always seemed...
if you are using a mere touch up kit ..i would recommend for about 15-30 cents buying a model paint brush the bristles are much smaller than what comes in the bottle and no you wont need to sand it at all after application it will look very dull but put it on and allow it to simply apply to the scratch only ....unless you know someone in the paint dept...and ask for a bit of clear to mix into the paint it will look dull upon finish
if you are good at airbrush i would suggest merely filling the scratch in just as i described earlier ...unless you are going to actually paint the entire area then your talking blending into either the adjacent areas or merely blending into the area around the scratch ...what ever way you look at it touch up paint will always look dull upon finish
Dec 11, 2009 | Buick Park Avenue Cars & Trucks
CAP AND ROTOR
on the cap the contact points inside will look coroded--not square edges and burnt spots where the rotor fires against,the rotor will look burnt on the tip and have rounded edges(in other words all metal parts in the cap and just the thicker metal on the rotor)the really shinny metal on the rotor will be black in spots where it connects to the cap in the middle but doesnt always go bad there
Apr 24, 2009 | 2001 Chevrolet Blazer
Cleaning the top
You can use a straight edge razor blade to scrape these areas. A good paint scraper with a wide blade and long handle works best. When done scraping, finish with a good cooktop cleaner.
Jun 01, 2008 | Maytag 30" Built-In Single Electric Wall...
Computers & Internet Logo
David Payne
David Payne
