SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
SOURCE: How do you update the time stamp on faxes/fax
should be under "user tools", "System settings, "timer settings"....."time/date", or something like that
SOURCE: Ricoh MP 3350 Fax Report
Hello sir; You may go to hit the user tool key on upper left corner of the control panal, the go to fax setting then go to reception page, you may change information you want.
SOURCE: I NEED TO RESET THE TIMER ON THE AFICIO MP C2000
Is the main power switch on? (not the one on copier operation panel)
SOURCE: I have a Ricoh Aficio
one has nothing to do with the other.but to get rid of the cannot connect to dhcp gotouser toolson the top u will see a few tabs.. select the network tab.one of the options will be ip . select it and select specify.then press ok and exit user tools. that will get rid of the cannot connect error.but again it has nothing to do with the faxing
