Question about Car Audio & Video
Is it possible to get a ford code with the frame no
  • Car Audio & ... Master
  • 17,167 Answers
Use the VIN and contact the dealer for additional information.
Posted on Oct 21, 2013
Just a curiosity question,going to buy a 2009 mondeo titanium x tdci 2.0 & the colour is just down as blue . I need the vin number to find out the proper name . Can you help me please ??
by the 2009 ford mondeo colour chart
possibles are
3CYCWWA-Ink Blue- Pearl -code E
8CWAWWA Blazer Blue - Solid- code A
car may have be resprayed or repaired
you need the colour code on the riveted plate or door frame sticker to confirm it is code A
any auto paint shop can make the 2009 up using its formula listing
or super cheap has small spray touch up cans
Apr 16, 2017 | Cars & Trucks
05 Ford Freestar has cylinder 2 misfire code, plug and coil replaced, runs good cold but starts to misfire uphill, when AC is on or after it warms up. What else could it be?
Maybe you replaced the wrong plug and/or coil?
Did you replace with new genuine Ford Motocraft parts?
Aftermarket parts are not as good as the O.E.M. parts many times.
Any trouble codes? If there are, what does the freeze frame data show. Is the fuel pressure within specs.?
How is the compression and are all the cylinders even?
Have you got a rich or lean trouble code also?
Check for vacuum leaks.
Possibly fuel injectors could be restricted?
Sep 22, 2016 | 2005 Ford Freestar
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
The only way my 1990 ford f150 enline 6 will crank is if fuel is put down the throttle body
Possibly the fuel filters are clogged, should be 2 both located on the frame rail, if not these could be your fuel pump relay, I would check these before going for the Fuel Pumps, yes there are 2 one in the tank and 1 on the frame rail.
Aug 04, 2013 | 1990 Ford F150
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Driver side electric window fell. How can it be fixed
Body shop guys can take off the door panel re attatch the window cable to the window frame possibly its one of those plastic link cables to raise your window But its kinda complcated to work that mechanism I would just see if the cable is broken on the window frame in the door frame
Jun 22, 2010 | 2004 Ford F150
Power steering pump return hose from steering box assembly diagram for a F250 ford
1999 F250 diesel. POwer steering fluid "pours" out of the trk when the steering wheel is turned. Does not leak when at rest, fluid coming out between the steering box and frame....is the a hose inbetween there or is it a possible cracked box (bolts are tight on frame)
Apr 18, 2010 | 1988 Ford F 250
98 ford taurus wgn se door ajar light wont go out
The switches that activates the door ajar are located on the body frame. For front doors try looking between the hinges, on the frame of the body cavity. Might have a rubber grommet around it. On the back doors, look on the frame of the body cavity near the hinges.
Apr 02, 2010 | 1998 Ford Taurus
1970 Ford F250 converted into 4x4
Its possible, myself i think it would be easier to put the sheetmetal from the 70 onto the 79 frame, but you can do it either way, but you might need a torch and welder, and a good drill and drill bits, i think if the cab mounts from the 70 match up with the mounts on the frame of the 79 it would be easier to switch the cab, box, and front end off the 70 to 79. there isent enough room here to explane everything, if you got questions i got answers. Just ask.
Feb 13, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
