Question about Refrigerators
GE refrigerator. The power comes off and on. I took out the evaporator fan and replaced same problem is present. I turn the refrigrator on without the motor being plug in and it runs ??
  • Refrigerators Master
  • 16,195 Answers
Sounds like the autodefrost is sticking. There should be a timer or board that controls that.
Posted on Oct 21, 2013
SOURCE: BM-23 Evaporator fan motor
mine runs all the time.
Posted on Jul 02, 2007
SOURCE: GE Refrigerator Eva. Fan Motor
which is the part number of the evaporator fan motor for refrigerator model GTS22KBP?
Posted on Nov 21, 2008
SOURCE: whirlpool side by side refrigerator not cooling
check t/stat or temprature controler and check the gasket for air leak.
thanks
Posted on Jan 05, 2009
BIKER T
  • 909 Answers
SOURCE: Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
Posted on May 23, 2010
  • 13 Answers
SOURCE: Evaporator Fan Motor noise is
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Posted on Aug 26, 2010
Get freezer to work?
Defrost system component(s) failure or a failed evaporator (cooling coil) fan motor failure. The fan motor should be located in the freezer section.
Sep 16, 2014 | GE Refrigerators
Not cooling
Roy,
Are the evaporator coils in the freezer frozen up?
The evaporator is located behind the cover in the back of the freezer.
If so this may be a defrost issue.
The adaptive defrost timer may have failed.
This is located in the ref. side inside the front control pannel.
If not then you may have a freon leak.
This would have to be repaired by a qualified technician.
Jan 15, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Evaporator fan works sometimes
by the sound of it , i would get a new evap fan,
as the power to the fan is switching on - thats why
you can flick it and get it running, the power is there.
it is a common problem with evap fans.
Dec 12, 2009 | GE GSS22JF Side by Side Refrigerator
A/C fan blows enough air but temperature is niether hot or cold
CHECK YOUR PRESSURE SWITCH. IT IS ON YOUR EVAPORATOR.
Aug 04, 2009 | 1999 Cadillac DeVille
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Nov 18, 2008 | Refrigerators
Refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Oct 13, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Fa does ot work replaced fan motor fa still does not come on
it's probably the board in behind the cover in back of refrig.it powers the fan. it's a good idea to replace white sensor on evap coil also if your fan didn't come with one
Mar 05, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
