Question about Electrical Supplies
Breaker in garage flips after installing new 3 way switches and outlets
I installed new outlets on switches in a new condo. All of the house works fine except for one outlet in the hallway, lights above the stove, and the garage. (When trying to turn on the breaker it flips) I need to know how to find the short as everything worked before. Is something not tight enough? Wire in something wrong?
    Master:
  • 482 Answers
Go back and check the wire colors on the devices that trip the breaker
Posted on Oct 21, 2013
  • danny Oct 21, 2013
    Black and white on outlet ftwo black on switch and a red black and white on three way
4 Suggested Answers
lkeithcombs
  • 11 Answers
SOURCE: How do I re-code my Raynor Garage door opener
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Posted on Jun 02, 2009
mkh5094
  • 145 Answers
SOURCE: Am doing a 'remodel'. Discovered the 2 lights in
Well you have to make sure of three things with three way switches...where your power comes in, where your power goes out, and that your travelers are not mixed up. Lets talk about a normal three way circuit. Power comes in to your first switch. You attach your power wire to the common terminal, usually a different color than the other terminals. The other two are your travelers, if your switches work partially you probably have these mixed up. The color traveler you have on one switch terminal has to go on the exact terminal on the other switch. Also check that your neutral is not swapped with a traveler, this will cause your eyes not to light. In between switches there is most of the time three wire cable (2 travelers and a neutral---while two wire cable is used before the switches and after it going to the light). The power then goes out of the common terminal of your second switch. If all wiring is good, I would take your switches out and check them with a continuity tester to see if they are bad. Check continuity on each switch between the common and each traveler terminal.
Posted on Jul 05, 2010
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Power from house to garage. i wont a switch to turn light on and a double power socket. please could you help me.
Just tap the power on your existing power breaker and laid off the new cable in pipe to your garage. For your socket outlet , you will need to install 3 wires ( +, - and G) and for light ( the switch in your house, you need also 3 wires like socket outlet)
Make sure to power off the electricity breaker before you commence the works.
Regards, Jay
Feb 15, 2011 | Hammering
One year old Danby dac8075ee, HAS NO POWER, what could be wrong ? please help
your air conditioner has no 'power' on it's own. It must get the power from an electrical outlet.
It is possible that the outlet you are plugged into is 'dead,' i.e. not working. One simple way to test this is to plug in another electrical appliance, hair dryer for example to test it and see if it's working.
If you do this and the other electrical device works then you know your AC is getting the 'power' it needs to operate - in which case you have a problem with your AC, and will probably need to call a Service Tech.
If, however, you plug in another device and it - too - does not work then you know the problem is within the outlet, probably a 'breaker' that is off or has tripped off. So, you need to locate the breaker - box.
This "breaker - box" (in most houses) will be located in the garage, utility room, or behind a door somewhere in the house, i.e. kitchen or bedroom.
If your outlet is not working - just go to the breaker box and open the door and look for a breaker (looks like a light switch) that is in the off position or perhaps half way off and half way on. Once you find this breaker - be sure your AC is plugged in and - just flip it (breaker switch) back in the "on" position.
Note: if the breaker switch trips right back off - then you know you have a direct short in your AC and probably will need the help of a Service Tech.
If this is the problem and the breaker stays in the on position and the AC runs and cools - you are probably ok, unless the breaker trips again in a short time span.
If that happens you most likely have a problem in the unit although it's possible the breaker is bad - in any event you are probably in the need of a Service Tech.
good luck!
May 05, 2010 | Danby DAC8003D Air Conditioner
Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
Dyson upright will not power up
As was my problem, checked and washed filters (both) checked all accessable tubes but problem was that the tube inside the drum and the tapered section at the top ws solid with dust.
remove 3 small screws in top (Torx heads) and clean out. Job Done!
May 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I re-code my Raynor Garage door opener Model 61 rdg (on Remote) Serial # 17592 (on opener) Year 1992? I am a new resident in the house with this garage door opener. The remote control opener worked...
Apr 03, 2009 | liftmaster Chamberlain Garage Door Opener...
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Electrical Supplies Logo
59 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
