Question about HP Wired Handheld Barcode Scanner
My scanner doesnt press enter after each scan
  • 4 Answers
What is is the model of the scanner? What you need to do is program a suffix carriage return.
Posted on Dec 12, 2013
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    How to porgram bc140police scanning radio
    First, you'll need a list of frequencies to program into the scanner. The BC140 memory is limited to just ten channels, so you'll need to select your coverage carefully. For a detailed database of active frequencies in your area, visit:
    www.RadioReference.com
    Once you have your frequency list:
    - Power the scanner ON.
    - Press the Manual key to stop scanning.
    - Select the channel to program (1 through 10) by either entering it on the keyboard and then pressing Manual again, or by repeatedly pressing the Manual key to advance through the channels.
    - Enter the frequency, including the decimal point (e.g., 156.055).
    - Press Enter (E) to save the frequency in the scanner's memory.
    - Press Manual to advance to the next channel and enter your next frequency.
    When you finish programming, press the Scan key to start scanning.
    If you enter an out of band frequency, one that is not covered by the scanner, the display will show E for error.
    Bill B.
    Listening in since the 60's
    Nov 01, 2010 | Uniden Radio Communications
    HOW DO I PROGRAM THE CHANNEL IN AND LEAVE IT ON SCAN AND IT PICK THEM UP
    To enter a known frequency into your scanner:
    - Press the MAN key to stop scanning
    - Press MAN repeatedly to select the channel to program
    - Enter the desired frequency, including the decimal point
    - Press E to enter your data into the scanner's memory
    Repeat the process for other frequencies, and press the SCAN button when you're finished programming.
    More detailed programming steps are presented in the factory operating manual, which you can download/print, free of charge, here:
    http://www.uniden.com/pdf/BC60XLTom.pdf
    For a comprehensive database of active frequencies in your area, visit:
    Bill B
    Aug 06, 2010 | Uniden BC60XLT Handheld Scanner
    How to program a bc855xlt uniden bearcat scanning radio
    Major Functions of Uniden BC 855 XLT Desktop Scanner
    RANGES AND MODES:
    29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
    MEMORIES & MEMORY SCANNING:
    • The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
    • To scan memory channels, press SCAN. To hold a channel, press MANUAL.
    • The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
    • Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
    • SPEED toggles between 8 & 16 channels per second in both scan & search modes.
    TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
    • Press MANUAL.
    • Press the channel number you wish to program using keypad.
    • Press MANUAL again.
    • Enter the desired frequency using the keypad.
    • Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
    • To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
    • To lock out channel from scan, select it & press LOCK OUT. Same deselects.
    PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
    TO SELECT CHANNELS MANUALLY:
    • Press MANUAL.
    • Press desired channel number on keypad.
    • Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
    TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
    TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
    • Press MANUAL.
    • Enter the lower frequency limit.
    • Press LIMIT.
    • Enter the upper frequency limit.
    • Press LIMIT.
    • Press SEARCH.
    I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
    http://uniden.com/pdf/BC860XLTom.pdf
    For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
    BillB
    Jan 19, 2010 | Uniden BC895XLT Base Scanner
    I cannot figure out how to program my scanner to the fire frequency.
    To program any known frequency into your BC72XLT, power the scanner ON, and then:
    1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
    2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
    3. Press E to store the frequency into the channel.
    Notes:
    • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
    • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
    • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
    • If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
    accept.
    4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
    Need the full manual for your scanner? You can download/print it here:
    http://uniden.com/pdf/BC72XLTom.pdf
    BillB
    Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
    I have a Regency Touch K 100 ( NO MANUEL ) Scanner
    I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
    http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
    For $5 it might be worth it.
    For all of your scanner needs: ScannerMaster
    Nov 17, 2009 | Radio Shack Radio Communications
    I dont no how to program my regency z30 scanner
    To program the Regency Z30
    1. Press "MANUAL"
    2. Enter the frequency you want, example 162.475
    3. Press "ENTER"
    The display will show "Ch_" with the _ (underscore) flashing
    4. Enter the number of the channel where you want to store the frequency.
    Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
    If you wish to add more frequencies at this time, got to step 2.
    To lock out a channel, press "SCAN" and while the unit is scanning,
    enter the channel number. Repeat this action to unlock a channel.
    To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
    To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
    You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
    Apr 07, 2009 | Office Equipment & Supplies
    Radio Shack Pro-82 Scanner
    when on the scanning part push the scan part again and push the prog buton that is under the lower arrow key and push it again so it will go to a different (blank channel) . you will know when it you are able to prog when the word prog will be on the bottom of the screen then go to cityfreq.com to find the codes for your area and put them in and then press enter. after you do that press the prog button again and it will move to the next number to program a different on when you get the desired amount of frequencies in your scanner just push scan and it will run through the entered codes.. Or if thats not the problem then on top should be a bank of numbers and andd you have to push the number of what bank you want it to run through at that time.
    Jan 25, 2009 | Radio Shack Pro-82 Scanner
    Automatic RETURN/ENTER ...
    I set scanner to defaults and had to Scan Bar Code labeled <DATA><SUFFIX 1> on page 4-50 of LS 2106 Product Reference Guide to set return after scan.
    http://www.intermeccorp.com/pdf/2106setup.pdf
    May 13, 2008 | Symbol Hotshot LS2106 Handheld
    BC72XLT
    Here is the directions to store frequencies in your scanner:
    Storing Known Frequencies
    Into Channels
    to store.
    Notes:
    Operation 2 seconds after the end of a transmission before
    accept.
    Dean
    Rollin CBs
    Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
    HP  Wired Handheld Barcode Scanner Logo
    127 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
