Question about Kenmore Ovens
Tappan oven tgb500ccb2
Igniter glows but no gas
Krazytech
  • 725 Answers
SOURCE: maytag gas oven mgr5770abb
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Posted on Aug 16, 2008
SOURCE: Tappan gas stove,oven not lighting
i am unable to use my oven on my tappan gas range. every other part of the range works wonderfully. the oven just will not light
Posted on Sep 11, 2008
  • 306 Answers
SOURCE: THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Posted on Dec 03, 2008
  • 2187 Answers
SOURCE: Gas oven igniter glows, but oven does not turn on.
That is correct. You will have to check if the valve needs replacement or if there is power being sent to the solenoid for the valve. There must be just a connection problem.
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Posted on Feb 01, 2010
Gas oven doesn't work
Sounds like it could be a bad Hot Surface Igniter, Check to see if you see glowing, if not, have the Igniter replaced.
Dec 05, 2013 | Tappan Ovens
Tappan oven tgfs26cba , oven does not light when turned on. control panel says it's working. glow plug glows hot. gas inot fed. was informed wife had taped oven vents to stop mice ??? could this have over...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 04, 2010 | Tappan Ovens
Oven will not come on...glow plug/igniter is illuminated, but no smell of gas.
most of the time this means that the ignitor is weak.if the broil and the upper burners are ok I would think to change it.
Mar 22, 2010 | Tappan Ovens
Feb 01, 2010 | Tappan Ovens
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Tappan #tgf605wfw5: igniter gets hot but gas valve does not open up. Part of the igniter bad, or the valve bad. How to check to see which one is bad?
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Glow plug on oven
Yes. Igniter stays on from just before ignition until just prior to burner shut down with each burn cycle.
Nov 12, 2008 | Tappan 30IN ELEC IGNa Oven
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Ovens Logo
35 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
