Question about Gbc HeatSeal Ultima 65 Laminating System
Ultima 65-1 GBC laminator- problem with film not adhering to each other. Can the temperature be adjusted.
4 Suggested Answers
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
  • 3 Answers
SOURCE: My ultima 65 laminator is not sealing well on the
I fix these machines for a living. As the machines age the heaters in the red rollers dont heat evenly and cool areas dont seal well. If you have a heat gun check the temperature along both roller. Some variation is normal but very cool areas that dont seal well point to needing new heaters. GBC machines work well but the parts cost a fortune. if one heater is going bad the other one is too, change in pairs ONLY, heater sets are near 300 bucks last time I checked:(
Posted on Jul 24, 2012
SOURCE: gbc heatseal ultima 65 won't turn on. It shut
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Posted on Dec 18, 2012
I have a GBC Ultima 65 Laminator and the lamination is not adhering. The materials I am laminating are coming apart.
Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Feb 14, 2017 | Gbc Office Equipment & Supplies
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Top roller of GBC ultima 65 not heating
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
westco laminating services....405-324-6092
Oct 23, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Film is wrapping around bottom roller instead of going out. how do I get it unwrapped?
Get a scotch brite general purpose pad, be sure to let machine cool down before you start to cleaned roller. And you can thread your laminate film.
Sep 03, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc HeatSeal Ultima 65 Laminating System Logo
80 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
