Question about Jandy AQUALINK RS TELELINK KIT
My water temp keeps showing 197 or higher temp. The air temp shows the correct temp
  • David Spradling
    David Spradling Apr 16, 2016
    replace water temp sensor on aqualink the one that goes to plumbing
  • 372 Answers
You need a new water temp sensor. This is an extremely common problem with the RS system.
Posted on Oct 28, 2013
When replacing radiator and thermostat in northstar engine ...is it necessary to disconnect the battery?
Robert , not really if you do disconnect battery MAKE SURE YOU US A MEMORY SAVER ,its a small battery supply that plugs into cig lighter and keeps all data fresh .did you check tention on water pump drive belt, ,is water pump good ,and after replacing radiator did you purge out all the air.,iknow these north star motors very well and keeping a good handle will keep it alive for years but these motors have a BAD track record of over heating and blowing head gaskets .
Woody
Sep 08, 2014 | 1997 Cadillac DeVille
Fan comes on; however, can't get the desired temperature to set. I select it and two seconds later it shows a higher temperature.
Hi Kate, When you press the button for your desired temperatre setting it will show this temp' say 17*c for a few seconds then it will revert back to showing the actual room temp' say 23*c, it should then cool the room down to what you set it at. hope this helps.
Sep 03, 2013 | DeLonghi CF210 Portable Air Conditioner
Ambient air sensor on 2005 Chrysler Town and Country showing -40
I would suspect the outise air temp sensor is defective, replace it. It is located in front of the AC condensor core.
Jul 19, 2012 | Cars & Trucks
I bought a used Goldline aqua logic system from a friend that moved and it was working fine.I think I am missing something like a Hayward Goldline Water/Air/Solar Temp Sensor GLX-PC-12KIT.On my system
You will need two temp sensors, one for water(two wires) and one for air(the other two wires). Look at the board and you should be able to see it labeled.
Apr 06, 2017 | Pool & Spa
My temp guage shows 130 to 135 but temp is at 197
Change the engine coolent temperature sending unit.Good Luck.
Dec 08, 2010 | 1997 Dodge Ram 1500 Club Cab
Air conditioner will not turn off, thermostat keeps showing temp inside getting higher, cool air is coming out of vents
Is there a heat source close to the thermostat, plug in transformer for a phone mabey, table lamp? If not then you have to have a bad thermostat. Any possible heat source from inside the wall? Will it shut off if you turn the system off? Turning power off to the furnace will shut everything down. If no heat source is driving up the indicated room temp, replace t'stat.
Sep 17, 2009 | Heating & Cooling
Overheated truck
Your radiator is getting clogged up with mud causing the lack of air flow through the radiator. You may want to install a mud deflector in front of your radiator to keep the mud from clogging up the radiator and may be run your antifreeze ratio 40/60 (antifreeze/water) the higher the water content the better the heat transfer, but your have to keep an eye on the level of the coolant level more often. Water will evaporate quicker but too muck antifreeze will have poor heat transfer and 100% antifreeze will gel when heated causing poor circulation causing overheating. Good luck and hope this helps.
Jul 12, 2009 | 1999 Ford F150 Regular Cab
200hp suzuki outboard goes into protective mode at higher rpms
You either have a bad temp sensor, insufficient amount of oil, or more likely a water restriction. With suzukis, especially the newer 4 stroke models, they have a tendency to not have the greatest flow of water to the intake, they have screens in the intake that are easily blocked as well.
Mar 29, 2009 | Boating
Engine overheats when heater pipes connected
I think you could be right about there being air trapped in the system.
Or the heater core(radiator) is plugged.
Either way you need a pressurized radiator coolant pump to put the coolant in without air being trapped.
Although,i have seen it done by jacking the vehicle up high enough that the radiator was now higher than the heater core level, and then the coolant was put in.
But this is dangerous to try.
Jan 29, 2009 | 1999 Ford Escort
Jandy AQUALINK RS TELELINK KIT  Logo
122 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
