Question about Ovens
Kenmore gas range convection fan not spinning
  • Steve
    Steve Oct 21, 2013
    My convection fan is not spinning when I run convection mode. It came with the house and I'm not sure if it ever worked. There is no voltage across the fan. I traced it back up to the PCB (Stamped with electrolux es52x_36x). Anyways I was checking the board over and something obvious jumped out. There is a wiring harness on there with three spots in it. There are three hookups - Broil, Bake, Conv - and there is no wire plugged into the Conv spot. So am I completely missing a wire that should be hooked into there, and if so how do I find where it should go so that I can add one in? The only other wire on the board with the same interface that would push into the wiring harness is also shown in the picture at left plugged into a spot labelled P5 / LX. I figured this might be the ticket so I unplugged the wiring harness and stuck it on the conv spot and fired it up with no love. Any help greatly appreciated.. thanks! Steve
  • Steve
    Steve Oct 21, 2013
    Model number is 970-339334 although when I google it the only result is an electrolux one, not kenmore elite and the control panel doesn't look the same. Presumably it's the same oven though. Also the was a part number on the control board that I didn't notice before - 3164627.
3 Suggested Answers
  • 833 Answers
SOURCE: Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Posted on Dec 21, 2007
  • 61 Answers
SOURCE: Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Posted on Dec 26, 2008
I have an american range gas convection oven i think lightning may have struck them but they still run but the gas will not come on the igniter just keeps ticking and no gas
there posible pilot burner is clogged, you may want take off the gas pilot tube and make a quick turn on to see gas is come out from pilot tube or disconnect from gas valve pilot connector...have fun....
Sep 23, 2011 | American Range Ovens
Kenmore Elite Gas Oven f1 message
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Bottom of kenmore oven pitted
Baked on debris causes this. The spots are from food sitting there without being cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 08, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Fan starts slow or not at all.
This is usually an indication that either the motor capacitor is bad or the start centrifugal switch in the motor is bad or, possibly both. Spinning the motor bypasses the starting process. Capacitor are fairly inexpensive, I'd do that first. If start switch is bad, motor has to be replaced. Not a cheap motor either.
Jan 19, 2010 | Garland Convection Oven - MCO-NAT Gas
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
69 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
