Question about KitchenAid Kitchen Ranges
Oven does not work, the display has a letter followed by a number, f 2
    Top Expert:
  • KitchenAid Master
  • 9,472 Answers
What is your model number?
Posted on Oct 21, 2013
Bosch oven HBN 1312.0
Please double check the model number on the unit. On the Bosch site, I found a number of models with that started HBN1312* . However the model number had another digit after the 2 and the zero was followed by a letter and a slash before additional numbers.
The model HBN131220B/01 is an all electric oven. The external dimensions for the wall oven are 595mmx595mmx515mm. I'm not sure about the internal capacity for the unit. Some documentation (including the user's manual) are available from the Bosch support site: http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM . Enter HBN1312 in the search box to find the documents.
I hope this helps.
Nov 24, 2013 | Ovens
Display lite not working
Your display can be economically repaired.
Here's a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 26, 2012 | Frigidaire Microwave Control Board -...
Error code F5E1
According to the manual, If the error code is a letter followed by a number, you need to reset the display.
Press LOWER OVEN CANCEL / OFF, UPPER OVEN CANCEL /
OFF or CANCEL OFFIf it comes back it needs to be serviced call
1-800-422-1230.
Please rate my solution, Thank you
Oct 26, 2012 | KitchenAid Architect Series KEBC107KSS...
I have a kenmore wall oven that flashes f7 every time we try to use it. and it turns itself off right in the middle of cooking and starts flashing the f7. Help !!!!
Kenmore recommends this:
The display of your control is flashing "F" followed by a number or letter. Oven malfunction. Press the CLEAR/OFF pad. Let the oven cool for 1 hour and place the oven back into an oven operation. If the problem repeats, call for service. 1-800-4-My-Home.
If you state the model #, I can look up the owner's manual for you and give you the link. Let me know.
May 22, 2010 | Ovens
My G.E. electric oven will beep and shut off after 15 min. or so. The read out says "F-2". What is going on?
This is what GE recommends:
“F— and a number You have a function or letter” flash error code in the display • Press the CLEAR/OFF pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the oven for at least 30 seconds and then reconnect power. If the function
error code repeats, call for service.
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Oven panel all lit up but won't work
control is the oven clock . look for a code in the display . if no code . unplug or turn power of 5 min and retry. may need a colck .. mm
Dec 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Open Questions:
Kitchen Ranges Logo
37 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
