Question about KitchenAid KUDS30IVBT Builtin Dishwasher
Sani rinse light stays on - KitchenAid KUDS30IVBT Builtin Dishwasher
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: KitchenAid Dishwasher KUDS01IJ will not
couple things you can try first hold down cancel for ten seconds this usually cancels the cycle and puts the unit in the drain function or you can try hit high scrub and than energy saver and repeated the same after a few seconds or if this also doesnt work then you could also try shutting of the power by way of the breaker for 5 minutes which usually causes the controler to reset if none of these tests work message me back and we can perform other tests also how many times are the lights blinking if its 3 times then these tests should correct the problem if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded Thanks Rick
Posted on Feb 05, 2011
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Tip
I have a KitchenAid KUDP02FR. Must be the same manufacturer because it has the...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Nov 06, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Normal wash and rinse only lights keep blinking on whirlpool gu1500xtls. tried cancel and uplugging and they still blink
Have Whirlpool GU1500XTLT1 with exact same symptoms, even tried power off but the lights resumed blinking when powered back up. Used solution from "kent168" of 17 Nov 2010 for similar GU1500XTLS1 with a different problem, and IT WORKED: "Reset the machine: press control buttons in this sequence: sani rinse, air dry, sani rinse, air dry, clear."
Jan 18, 2012 | Whirlpool 24 in. GU1500XTLS Stainless...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwarsher
This worked great - press Sani Dry, then press Heated Dry - then repeat - press Sani Dry, then press Heated Dry. All control lights will light and then press Cancel. The control panel should work normally.
Nov 05, 2008 | Kenmore 24 in. 17033 Built-in Dishwasher
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean light flashing dishwasher
Nov 22, 2007 | Dishwashers
KitchenAid KUDS30IVBT Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
