Question about Crosley CDE6000 Electric Dryer
Timer switch has to be rotated around many times and jiggled for the dryer to come on.
    Top Expert:
  • Crosley Master
  • 34,188 Answers
The timer could be defective.
Posted on Oct 21, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: first dryer timer stays on and doesn't cycle.we
Sounds to me like a bad timer...
that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
How to set time
You posted under Intermatic TN11C timer.
If you have a different timer, then add a comment and describe timer, or add a comment and include photo of your product for best answer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
TN timer comes with red and turquoise trippers
Red OFF tripper #107TN222
Turquoise ON tripper # 107TN221
Place trippers around outer edge of dial at on-off times you select.
Turn lamp ON, plug lamp into timer, plug timer into wall.
Manually rotate dial clockwise to watch lamp turn on-off.
Move switch on top of timer both directions to see how to set switch.
After setting switch and trippers, manually rotate clock dial until current time line up with arrowhead located on inner dial.
Dial rotates as time passes, and trippers push switch that turns lamp on-off
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Intermatic TN111C Standard Lamp &...
HOW SET TIME ON AND OFF
You posted under intermatic 1020 timer
If this is not your timer, add a comment
How to set timer.
Remove dial from body of timer.
So now the timer is apart in 2 pieces.
Silver ON trippers and brass OFF trippers can be removed.
Place trippers in times you want timer to operate.
OFF trippers have to be at least 2 hours apart.
ON trippers have to be at least 2 hours apart
Minimum on-off function is one hour
Snap timer back together.
Rotate dial around until current time lines up with mark
Dial rotates with passing time.
Tripper rotates around with dial.
When tripper contacts on-off lever, it physically moves lever like turning light switch on-off.
ON tripper moves lever one direction.
OFF tripper moves lever opposite direction.
Manual E-1020
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Dec 11, 2010 | Intermatic Timer E1020, Single pole/single...
How to set on at 4 pm and off at 7am
How to set timer.
In this case, set silver ON tripper at 4pm
Set brass OFF tripper at 7am
Timer comes with 2 pair of trippers, so you will only use one pair.
Save the extra pair of trippers for when 1st pair of trippers wears out.
Manually rotate dial around to watch lights come on.
To set current time, rotate dial until current time lines up with mark.
Manual E-1020
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Timer button won't rotate and dry time is very long
The timer has a little motor in it that causes it to turn and it sounds like it has failed. I'm assuming you can manually turn the timer all the way around. If you can, then it is not mechanically stuck. It's the motor within the timer.
Replace the timer/controller.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Hotpoint NWSR483EBWW Electric Dryer
When i set the time on dryer and then push the button to start then dryer will run for a few minutes but then stops but still has a ticking noise
Your problem could be a faulty timer.
Watch the time and see if it rotates to different cycles. If it does not rotate to different cycles then you may need to replace the timer switch
Sep 25, 2009 | Whirlpool Dryers
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
29 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
