Question about Kyocera Switchback KX21 Cellular Phone
Strobe wont boot?
Without the wall plug phone wont power up at all...and when i give it wall power i get a message on the inside screen that says" crash dump analyzer 2.1 nested crash" is this bad can it be fixed ...am i done for? please help thnx!!
  • 1 more comment
  • fgrtdse Nov 09, 2007
    crash dump analyzer 2.1 nested crash shows up on my phone when i turn it on can it be fixed
  • Anonymous Nov 16, 2007
  • jennshit Dec 04, 2007
    KYOCERA k132..crash dump analyzer 2.1 nested crash shows up on my phone when i turn it on
    Master:
  • Kyocera Master
  • 615 Answers
Just one app- LEO Privacy. It concluded many features: boost, anti-theft, charger protection as well as privacy protection.
Posted on Sep 08, 2016
    Master:
  • Kyocera Master
  • 386 Answers
What a pity, have the same problem. But LEO Privacy help me solve the problem. LEO Privacy is probably one of the best privacy apps ever. Also there's this thing were it boosts your storage, which it does, but I still have to go in the settings to clear somethings. But an app can only do so much so I don't worry. You should get LEO Privacy.??
Posted on Aug 11, 2016
You have to go to the store where you bought it or the metro pcs corporation building because they told me that when i called ...
Posted on Jul 09, 2008
Had The same problem it cant be fixed you have to go were you bought it and get it replaced.
Posted on Jan 21, 2008
SOURCE:
My motorola atrix 2 wont turn on
try pressing power key + home key + volume up key at the same time, see if you can boot to recovery, then, once rebooted, select clear cache partition, then select wipe data/factory reset..
and better not use a charger not compatible to your phone.. hence it would burn those leads inside..
Dec 29, 2012 | Motorola Mobility Atrix 2 - 8gb - Black...
My iphone was acting up so I rebooted it and now it wont turn back on the apple will come up and then the circles thing like its loading but then the screen turns black and wont turn back on!! I dont know...
Try powering off your phone and then when its off, hold down your power button and the button on the front of the phone until the apple logo appears and wait a little, it might take a while for your phone to boot up to home screen and to get a signal so just give it time to catch up with it self :)
Hope this helps & give me a message back if you have any question or it doesnt work! :)
(Please Leave Feedback)
Jan 07, 2011 | Apple iPhone Smartphone
Printer wont boot up.
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality
Mar 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
When I Power up My Motorola Razr V3 I get boot loader message
At you the program has flied, the software loader therefore is loaded. You should program phone again. Programs are for this purpose necessary the driver, cable USB. Or give to repair.
http://heaters.agilityhoster.com/
Aug 09, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Presario wont turn on. its an f500, i turn it on and it immediately turns off, screen wont come on...im assuming i need a new battery? want advice before i purchase the battery!!
Remove the battery, plug the wall adapter in and try to boot. If it works, the battery is the problem. If not; is the green indicator on the power brick on? If not, replace the power supply brick. If all the above is ok, the problem is internal and I would be guessing without testing.
Jul 25, 2009 | HP Compaq Presario F500 F700 and G6000...
Moto Q Sprint Phone wont turn on
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
Feb 11, 2009 | Motorola Mobility Moto Q
Kyocera strobe phone crashed
my kyocera have a probleme crash dump analyzer 2.1 nested crash
Aug 16, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Help with kyocera strobe on alltel network
I asked Alltel customer service and they said the phone is not capable of it. Mine come through as symbols. I just bought this phone on Ebay but it will be back on Ebay shortly.
Mar 15, 2008 | Kyocera Switchback KX21 Cellular Phone
STROBE WON'T CHARGE
you gotta go buy a new charger,or see if your company will replace it.The chargers for the strobe are garbage
Oct 19, 2007 | Kyocera Switchback KX21 Cellular Phone
Kyocera - Strobe
Open your phone to the qwerty keypad. In the righthand corner above and between the speaker and power/clear buttons, there should be a whiteish little button. Is anything obstructing it? Try pressing it gently a few times with a small phillips screwdriver or a ball-point pen top. GENTLY being the keyword! When you push that down, your outer screen should be lit up, and when you release it, it should light up the inside screen. Note that when your inside screen is lit, that your outer screen should light up blue-black-purple, and vice-versa.
If there is no obstruction that can be easily removed or fixed, I reccomend returning it to the retailer/company for a refund or new phone.
As a strobe owner, I understand your frustration. Worst phone I've had so far.
Sep 29, 2007 | Kyocera Switchback KX21 Cellular Phone
Kyocera Switchback KX21 Cellular Phone Logo
342 people viewed this question
Top Kyocera Cell Phones Experts
Mufaddal  Kurlawala
Mufaddal Kurlawala
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
