Question about Daisy Powerline 901 - 0.177 Caliber Powerline 901
Losing air pressure
Feel lose of pressure while pumping
    Sergeant:
    Champion:
  • 214 Answers
Try oiling the cup with air impact wrench non-fluid oil or 3 in oil
Posted on Oct 21, 2013
In 4 months we have pumped the tyres up every 2 weeks after losing 10 psi. Tyres and wheels are good cond. Are the sensors to blame
Are these the original tires? I had the same problem with a BMW years ago with my first set of replacement tires. Turned out the wheels were porous, and the air was leaking through the wheels. We needed to put tubes in the tires. If all 4 are going down at the same rate, that may be it.
Oct 06, 2015 | 2007 BMW X3 2.0D
Why does the pump lose pressure? there are no visible leaks, of water or air
for the pump to lose pressure there has to be a leak somewhere please check and make sure you have a one way valve on the bottom of your jet pump that will not allow the water to run back into the well
Nov 29, 2014 | Utilitech 1/2-HP 9-GPM Shallow Well Jet...
My suburban when you take off some times it feels like it has no power and also it sometimes feel like it lose powers going down the road
a tuneup with new distributer cap--plugs--wires works----also new air cleaner--fuel pump may be worn-get a pressure test----transmission cud be worn also along with torque converter-hav a pressure test done also--inspect fluid-if dirty and low-changeit--dont flushit
Oct 12, 2014 | 1997 Chevrolet Suburban
Losing power while pumping air rifle
oil the air cylinder , thats most likely your problem
Oct 21, 2013 | Daisy Powerline 901 - 0.177 Caliber...
P0452 Code on 1999 Sierra 5.3L Z71 Low Circut Voltage & Losing Fuel Pressure When First Running
Sounds like a TPS (throttle position sensor) problem. When encountering drivablity problems, start with cheapest parts first. The TPS and MAF ( mass airflow sensor) effect Fuel mapping (delivery). Replace Air filter often ( 40,000 miles) for good air flow. Also high humidity (rainy weather) combined with a dirty air filter can put MAF out of range. Also the MAP ( manifold absolute pressure) sensor should be checked. Along with regular air filter changes, I always add a can of B&G44K fuel additive to a full tank of fuel. This additive is the best on the market and should not be substituted. It will condition the fuel pump and the injectors. Also improvement in fuel economy. Do an OBDII test and delete any stored faults.
May 02, 2017 | Cars & Trucks
Losing pressure after about 15 mins pool pump stars really well but then seems to lose pressureleaf catcher before pemp seems to get air in it is this pump or pipes
If the inlet strainer gets air in it, the pump will lose prime. Fill the inlet strainer basket with water, make sure the cover is on air tight. Start the pump and watch the inlet strainer, the amount of air trapped should not increase, if it does, you have a leak somewhere on the piping between the pool and the pump.
Nov 19, 2010 | Plumbing
While traveling engine will hesitate, ****, lose power
Check the least expensive first. Check the fuel filters first and replace them if they are plugged. Most likely it is the fuel pump. A shop can check the fuel pump pressure at the fuel rail on the engine under the hood. If the filter or filters were checked first then a low pressure would indicate that the pump is weak and needs replaced.
Jan 21, 2010 | 1996 Jeep Cherokee Sport
Daisy Powerline 901 - 0.177 Caliber Powerline 901 Logo
188 people viewed this question
Top Daisy Optics Experts
BJ Russell
Andrew Taylor
Andrew Taylor
Are you a Daisy Optic Expert? Answer questions, earn points and help others
