Question about Husqvarna Chain Saw 20" Bar
Power loss, fires up fine, new gas, new filters, stalls and shuts down when throttle is on
    Sergeant:
    Champion:
  • 214 Answers
Probably the screen in the carburetor needs to be cleaned.
Posted on Oct 21, 2013
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: 25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
Posted on Oct 16, 2009
dontbother10
  • 2220 Answers
SOURCE: my husqvarna chain saw bogs down even without chain on it.
I think your "L" adjustment is off by a little, but because it will not hurt, costs nothing, and might be the cause of this, remove, clean and reinstall the muffler and spark arrestor. If the problem persists try this, it is by far the best carburetor adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. Good Luck. HTH
Lou
Posted on Feb 24, 2010
Robin Subaru EX40 engine will only run at idle. Increasing the throttle causes it to stall.
Try blowing your gas line out.. sounds like your getting gas but not enough
Oct 13, 2014 | Motorcycles
Robin Subaru (14 hp) engine will only run at idle. Increasing the throttle causes it to stall.
I had a similar problem on a weedeater one time, have you checked the exaust for a blockage?
Oct 12, 2014 | Motorcycles
Car is stalling at idle, loss of power, and gas smell in vents when started
Throttle position sensor or mass air sensor, more than likely TPS sensor going bad and hasn't thrown code yet.
Mar 27, 2014 | Chevrolet Malibu Cars & Trucks
Starts fine then stalls after a couple seconds.
its could be the fuel pump, if its going bad then it could be causing stall and a gas hose could be bad to and is only allowing a little gas to motor causing it to stall also
Aug 11, 2012 | 1998 Subaru Legacy
92 dodge dakota stalling,running rough,loss of power
Did you replace the fuel filter when you replaced the pump ?
Was it running rough before the pump was replaced.
Did you replace the cap and rotor too ?
"Sucking a ton of air" could be a vac leak, or the sound of the throttle open when the engine is bogging down.
Is the check engine light on when it is running ?
Jul 05, 2012 | Dodge Cars & Trucks
Car is not getting fuel 2001 sunfire changed fuel pump fuel filter fuel regulator. car will start and run fine drive too the store and back shut off will just crank over might try to fire one time then let...
Classic bad ground to the fuel pump...Mine did it untill I hard wired it to a switch with a power light. Car stalls light out I throw the switch and im in control but remember to shut it off or your battery will be dead lol.
Jul 06, 2011 | 2001 Pontiac Sunfire
I have a 1991 Olds cutlass ciera 3.3 v6, starts up fine when cold/cool. Runs down road fine till warm, then stalls, will not restart. Cranks fine, just won't fire up. You can pull air filter, sprinkle...
Good Evening, you might want to check those injectors, I can not remember for certain but that setup was sequential and when one or two have a problem it would take out the rest. Ohm out the injectors and see what you have there.
Nov 03, 2010 | 1991 Oldsmobile Cutlass Ciera
Van stalls,loss of power
possibly replacing the MAP sensor
Oct 08, 2008 | 1992 Chevrolet Astro Extended
Iroc z needs help
have you checked the fuses?
Jul 21, 2008 | 1990 Chevrolet Camaro
Husqvarna Chain Saw 20" Bar Logo
55 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
