Question about LG Dryers
I have pushed the reset button and my LG DLG7188WM gas dryer resets for a short period of time usually one load then the reset button disengages and my dryer doesnt get hot until I reset the button. What is the problem?
aborcass
  • 2651 Answers
SOURCE: No heat in dryer and can't find reset button
lg is a little more tricky to get apart, but ther are a few screws infint of the lint filter housing, as well as afew under the main lid."pop" the top by inserting a screwdirver into the clips located on either side perhaps 3 inches in or so.and then trher are a few phillips head screws that willl release the front panel,along the bottom right side is a few thermostats as well as a heater asssy, one of the thermostats have a red button protruding from betwwen the 2 wires, try pushing it in.it will reset the thermostat(its gotten too hot and "popped" for safety reasons...CHECK YOUR VENTING
Posted on Mar 30, 2008
SOURCE: Clothes dryer not getting hot enough to dry in a good time frame
i have a hotpiont TDC32 i have changed heating element and thermastacs and it still does not get as hot as it should it takes ages to even half dry has anyone got any ideas please i have cleaned all the filters etc...
Posted on Sep 18, 2008
RepairClinic
  • 32 Answers
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Posted on Feb 05, 2009
Unplug the dryer. Disconnect the vent hose from the wall and clear any lint etc. from the opening. Anything clogged with lint will continue to cause the heating element to "trip" for safety reasons.
Open the top by pressing in on the hidden metal clips on the right and left front (there is a small gap below the top section) Use a putty knife or screw driver to press in on the clips. Lift up like a car hood and then prop it up while you're working. Next open the dryer door. Remove the two screws on either side of the lower opening. Now lift the front up and out, set off to the left side as it is still connected by a wire. Look into the lower right side of the dryer with a flashlight. The reset button is located between the two wires that attach to the outside of the cylindrical drum at the 7 o'clock position. You need to be lying on the floor so you can reach your hand in. It is about halfway into the dryer. Press the button. Now reassemble the dryer before you start it up again. For a gas dryer - let it run and you should hear it "fire" up within a minute and the heating will begin.
Posted on Mar 19, 2009
omaharox
  • 161 Answers
SOURCE: Our LG TROMM DLG7188WM dryer has no heat
Several things can be the problem.
Is 220v present @ the outlet?
Heat element?
High limit thermostat?
Main computer?
Bad dryer cord? Ect...
Proabably time for a service call.
Posted on Jan 16, 2010
I have an lg 5988 dryer, only will stay heating on delicate cycle. any other cycle I have to reset, by pushing the button on the sensor on the exhaust inside back of dryer. I replaced that sensor 3 ti
Sounds like a airflow problem. Either the House vent is clogged or some major build up in the blower or lint housing.
Remove the vent hose from the dryer and see how well it is blowing, then reconnect the vent and check outside, it should be close to the same.
House vent should be short and strait as possible, and metal venting only.
Dec 27, 2014 | LG DLG5988 Gas Dryer
My LG gas dryer has had the thermostat sensors replaced and reset twice already, but after a few loads it stops producing heat. I have taken off the new exhaust outlet as I think the flapper may be...
You will need to disassemble the top panel, the control board, the front panel and the drum assembly to get access to the reset switch. LG has posted that once the button has tripped, it is recommended that it be replaced rather than constantly resetting the button.
Good luck.
Sep 28, 2010 | Dryers
LG Gas Dryer (dlg0452w) needs a push to get going
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 19, 2010 | LG DLG0452W Gas Dryer
Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Feb 21, 2010 | Whirlpool Dryers
Heat element?
Main computer?
Jan 12, 2010 | LG Dryers
Have a LG gas dryer dlg7188wm....doesn't heat
Take top off, then start unit. You can see orange glow in about 10 seconds on front bottom right by looking down from the top if the glow igniter is working.
Jul 27, 2017 | LG Dryers
LG model DLG5932W dryer wont ignite
Check your venting. Eliminate all or as much flex ducting as possible, replace with rigid or semi-rigid aluminum. Make sure outside vent opens a full 4 inches, not just two inches (or that louvers are clear of lint build up), and clean out all vent pipe of lint. Make vent as short as possible, with as few turns as possible. You may have to reset the high temp thermo again also until vent problem is corrected.
Apr 07, 2009 | LG DLG5932W Gas Dryer
LG DLG7188WM runs but no heat
I believe that it does. All of these parts should be functioning properly in order to dry the clothes well.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
Dryers Logo
54 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
