Question about Horizon Exercise & Fitness
Don't know how to start the treadmill - Horizon Exercise & Fitness
    Top Expert:
  • Horizon Master
  • 12,223 Answers
Read your owner manual. download from www.fitness.manualsonline.com
God bless you
Posted on Oct 22, 2013
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
I have a centaurus treadmill CF9010 and i don't know where to put the safety key to make a calibration of a treadmill. Can anybody help me pl?
downlod the instr. manual and see how to start. go to
normally the safety key, is in the display board down in the midlle at panel.
God bless you
Dec 10, 2012 | Exercise & Fitness
Hi i have horizon treadmill t401 i don't when i start it 3 miles for hours for my workout it stoped and restart very fast i don't no what to do can u tell me how to solved the problems please
1)this a problem by lack of maintenance schedule. LUBE the deck belt, probably you have a worn deck belt.
2) Lube the rollers bearings too , inmediately.
3) measure the input voltage motor in the terminal, if there are the motor need repair.
4) measure the output voltage board, if there are NOT the board is faulty.
se the block diagram. attached. see my personal TIPS
God bless you
Oct 07, 2012 | Horizon T401 Treadmill Walking Belt
Display shows wait and don't start
Dear Sir:
Please adjust the reed switch, clean, and tigh the connector very well.
See the diagram attached. Run after you fix the software calibration.for diagnose, troubleshooting.
sincerely. God bless you.
May 02, 2012 | Life Fitness 95Ti Treadmill 95 Ti
When walking on it as just a treadmil, it feels like one belt starts going the other way... I don't know how else to describe it. It's a bit scary. Is this a known issue and can it be corrected?
hi,
You have to tighten the treadmill walking belt. The following video will help you to do that. You need an allen wench for tighten the screws. All treadmills have follow the same procedure to tighten the walking belt
ok
Sep 12, 2011 | Bowflex Treadclimber
I plugged it in and it will not start. It was working fine yesterday but now nothing.
Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your treadmill to find the elevation motor. The treadmill fuses are located inside the elevation motor. If you don't have the manual, contact the manufacturer of the treadmill and ask if it can send you one or if there is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its side and use a screwdriver to unscrew the lid off the elevation motor. Carefully remove the fuses. Some treadmills have easy access to internal parts where you don't need a screwdriver. If this is the case, simply lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
Sep 06, 2011 | Sears Exercise & Fitness
How do you change the language to English on a life fitness treadmill? Currently it is in German. I don't know which model it is.
Dear Sir:
I see what is your problem.
1) Go to the menu in the computer of the Treadmill.
2) See the section Language, appear various alternative language, select:English and is Done!
3) Evey Equipment and Model, has this alternative in the software operation.
I hope your enjoy, your machine, ang Get Ready with fitness Treadmill.
Contact me, if you Can not do it.
Best regard.
E. Cuadra
Sep 05, 2011 | Life Fitness Exercise & Fitness
Hello - when I turn on my reebok treadmill, the only buttons that work are start and incline (incline works most of the time). All of the other buttons do not work. Its a Reebok Vista RBTL13305 model...I...
Let me know if you find a solution. I am having the same problem and cant figure it out. It turns on and will start but none of the other buttons work. Its so frustrating.
Aug 14, 2011 | Reebok Vista Treadmill - RBTL13305
I'm considerin buying treadmill from canadian tire poform 695 can you give me a device on this brand .
if you really want to know what people is saying about this machine go to the main site of the 'manufacturers and see the blogs, i'm pretty sure the constant posting of the customer's comments don't lie.
Apr 09, 2011 | Proform 695 LT Treadmill
Reebokrt1000 treamill not workng
Maybe check the manuals troubleshooting section?
If you don´t have one, check here.
May 05, 2009 | Reebok Rt1000 Treadmill Walking Belt
Exercise & Fitness Logo
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
