Question about Tyan ASUS A8NE-FM/ROHS/S / A8NE-FM NVIDIA NFORCE4 CK8-04 STANDARD- A02 SOCK
Non-stop beep sound and won't display
A constant beep, usually indicates the post is detecting no memory installed. This is usually caused by the memory not being installed correctly or incompatible memory. double check you have the correct memory for this mother board. If you have 2 chips, install one and test. If this does not work swap the memory and try again. If both chips fail, you might try a different brand of memory.
Jan 27, 2012 | ASUS A8N-SLI Premium Socket 939 NVIDIA...
Is there a serial number on a the motherboard itself? I have asus A8N-SLI deluxe that is not putting out any display. And need S/N and dont have the box it came in.
You do not need the serial number to download the video driver, but you need the motherboard number, this is printed on the motherboard.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Dec 16, 2010 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Sata drive wont boot, at boot up it not reconziged
Go in the BIOS and set the SATA disks to be recognized as PATA (probably called legacy mode)
Nov 22, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
I have a burnt out fan chip and was told that I need to replace my mother board - it is an asus a8n-e where can I buy one
There is a problem with the Southbridge chipset. The nForce4 chipset over heats.
Asus has not made a better cooler for the nForce4 Southbridge chipset.
(It does not cool the chipset as it should).
You will have the same trouble with a new A8N-E MB.
Sooner or later if you do not change the chipset cooler with a stronger fan/heatsink assembly like any of the ones listed on the next link, the chipset will burn up.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=498&name=Chipset_Fans
Here is the link to Asus for a replacement chipset fan;
http://estore.asus.com/shop/category.asp?catid=133
Try this link for the board;
http://www.tamayatech.com/parts.php?i=A8NE
Here is the Google search link for the Asus A8N-E board;
http://www.google.com/search?hl=en&q=buy+asus+a8n-e&aq=2&oq=buy+Asus+A8&aqi=g6
Than click the link below for other compatible Socket 939 motherboards with PCI-E x16;
http://www.smarterdeals.com/hardware/goods-sc_id-4890.html
Thank you for trying FixYa
Mike
Jun 23, 2009 | ASUS A8N-E Motherboard
Hi I have V2 marked on my A8N-E looking for updates
The V2 you see stands for, nForce4 Ultra.
To download the drivers for your Asus A8N-E board click on this link;
http://support.asus.com/download/download.aspx?modelname=A8N-E&SLanguage=en-us
Choose your operating system from the drop down window & click the Search button. All drivers, manual, bios files, utilities ect will be listed. (Never flash the bios unless you are correcting an issue).
Asus eStore link;
Cheers!
Mike
Apr 25, 2009 | ASUS A8N-E Motherboard
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Describe your ASUS A8N-SLI Deluxe nVidia video card
Yes, you do. Your board was built with the idea to use 2 graphic boards to get great video
NVIDIA® SLI™technology revolutionizes PC performance by combining multiple PCI Express GPUs in a single and scalable system! Gamers and hardcore enthusiasts know that dual GPUs mean increased, supercharged 3D graphics and performance
Dec 09, 2007 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Tyan ASUS A8NE-FM/ROHS/S / A8NE-FM NVIDIA NFORCE4 CK8-04 STANDARD- A02 SOCK Logo
54 people viewed this question
Top Tyan Computers & Internet Experts
Jerry Umali
Robert Graf
Are you a Tyan Computer and Internet Expert? Answer questions, earn points and help others
