Question about Xerox Office Equipment & Supplies
The repeating dots are not disappearing after replacing all of the imaging units
  • 40 Answers
If the dots are about 3 inches apart you will have to replace the fuser of clean the debris off causing the marks, if there further apart its more than likely to be your transfer belt check and replace if necessary.
Posted on Oct 21, 2013
  • Xeroxrep Jun 25, 2014
    And your copier/printer model is what?
Printer repeating same image
replace the image unit magenta or fuser unit
Jan 12, 2014 | Konica Minolta Office Equipment & Supplies
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Blue dots on black images
I can tell you that I had my plasma screen replaced in the 4th year. The tech told me that the replacement panel was much more reliable. You may be looking at replacing the plasma panel...(which may be more expensive than replacing the whole unit??).
Jan 29, 2013 | Samsung HP-S4253 42-Inch Plasma HDTV
Red dot
if the red dot occurs in a constant patter across the image there is damage to the magenta drum and it will need cleaning or replacing the yellow streaks lead to the yellow drum or dev unit needing cleaning or replacing.
Jul 21, 2010 | Canon imageRUNNER C3200 Copier
While printing a document some ink dots are coming in every page of document
Did you replace the toner? dirty print out might be the sign of low toner or faulty drum unit.
But if the dots are repeating on same line..then most probably it's the drum or fuser problem.
May 24, 2010 | HP LaserJet 1020 Printer
I have a bizhub C450 and i am getting a yellow line at the top of my printed page and also 2 pink/red dots in the middle of the page. How can i stop this?
The yellow and magenta image units may be the problem. Yellow may have worn out on one end causing the yellow line. If the pink dots show up on every page but move around from page to page, there may be damage to the magenta image unit. You can remove the image units from the machine and look at the drums (long green cylinders), this should be shiny and clean. If not, you may need to replace.
Apr 28, 2010 | Konica Minolta bizhub C450P Laser Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Live dot in printing what is problem
is the dot repeating... if yes.. then try replacing the toner unit.. normally the dot is on the drum..
Feb 19, 2010 | Canon LASER SHOT LBP-2900 Printer
Can smears when priting be fixed
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Apr 16, 2009 | Brother HL 5250DN Laser Printer
74 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
