Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Dyson DC28 - when using this in "carpet mode", I can hear and feel tons of suction being pulled through the wand, even though the wand is properly stowed as the handle for "carpet mode". And when this happens, the beater bar and suction to the base is not enough to effectively clean the carpet. This happens intermittently. I have cleaned all filters, inspected/removed (when possible) all hoses, no blockages have been found. Is there a "switch" that changes the mode from "carpet" to "wand"?
    Novelist:
    Champion:
  • 210 Answers
There's no switch per sey, but there is a clutch activation knob, on the right side of the base, as you're standing behind the unit. There should be a Carpet or Hard floor setting, just two. Twist it to change from one to the other. However, all this is meant to do, as far as I know, is to turn on the brush roll or turn it off, by means of a clutch system. I don't think it has anything to do with the wand assembly.
Posted on Oct 23, 2013
5 Suggested Answers
SOURCE: Suction loss when handle is tipped back to clean carpet
Ours did the same thing. I cleaned the filter and canister thoroughly. It needed to be cleaned, but that didn't fix the problem. I removed the plate under the carpet brush bar (three quarter-turn screws) and removed all hair, lint and threads from the rollers and brush. THEN my husband found the real problem: a piece of flexible hose running from the head into the hose (on the left side when behind the vacuum) was completely clogged. The hose will detach from the head, and you can remove debris. Once that clog was removed, the hose easily re-attaches, and we had great suction once again.
Posted on Feb 14, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
Dysonteam
  • 167 Answers
SOURCE: No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Posted on Apr 22, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: suction only coming through the wand when its replaced its not switching back to the upright. I have a dyson DC28 animal
    Hi there, it's Jack at Dyson.
    I'm sorry to hear your DC28 doesn't seem to be working correctly. It sounds as though the change-over valve may be jammed - this diverts the suction to the hose when you remove the wand, and back to the cleaner head when you replace the wand on your machine.
    You may find a blockage is jamming the valve - you can check for this using our online Support guide:
    http://content.dyson.com/support/help.asp?article=1236&product=DC28-ANIMAL
    If you can't find any obstructions, please get in touch with us directly as we'd appreciate the opportunity to provide further assistance. If you email us at askdysonUS@dyson.com, we'll be in touch as soon as possible.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Dec 06, 2012
    No suction when I release the wand
    If your DC28 doesn't seem to have suction through the hose, it's likely you have a blockage in the hose, wand or airway. To check for this, please follow the steps shown in our online Support guide:
    http://www.dyson.com/support/dc28/dc28-animal/diagnosis-root-menu/dc28filterwashvid/wand-suction-dc28
    This should resolve the issue, but if you need further help after giving this a try we're on hand to offer advice. Just give us a call 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a repair or replacement part is needed, we can also confirm if this is covered under our 5-year warranty.
    Oct 12, 2014 | Dyson Dc28 Animal Airmuscle Vacuum 00247
    Long and short tubing
    Hi Sharon, it's Jack at Dyson.
    To replace the internal hose (the short section of flexible hose underneath the cleaner head), please follow the steps shown in the video above. The internal hose has a push-fit connection at both ends - please make sure it's pushed firmly into place.
    To replace the main hose at the rear of the machine, please take a look at our Support guide: http://www.dyson.com/support/dc28/dc28-animal/diagnosis-root-menu/dc28filterwashvid/wand-suction-dc28/wand-from-hose-dc28/hose-suction-dc28/redirect-to-check-the-hose-dc28/check-the-hose-dc28
    If you remove the clear bin and cyclone pack from the machine as if you were about to empty it, you should see the hose release tab to disengage the hose from the machine.
    I hope this helps, but if you need any further guidance please email askdysonUS@dyson.com, and one of our experts will be in touch as soon as possible.
    Best wishes,
    Jack
    www.dyson.com
    Nov 07, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
    When my dc28 is in the upright position, the wand will not suck-only when the vacuum is in the back position. also, the brush part will not suck at all in either position. my husband said there is a...
    Hi Lindsay, it's Jack at Dyson.
    I'm sorry to hear about this. When your vacuum is standing upright, the suction should be automatically diverted to the wand and hose for above-floor cleaning. From what you've described, it sounds like your machine may have a blockage, or something jamming the changeover valve which is preventing it from moving freely.
    To check everything is correct with your machine, please follow the steps shown in our online Support guide: http://www.dyson.com/support/dc28/dc28-animal/diagnosis-root-menu/dc28filterwashvid/wand-suction-dc28
    This should resolve the issue, but if you would like some further advice after you've given this a try, our experts are happy to help. You can reach us by emailing askdysonUS@dyson.com.
    Best wishes,
    Jack
    www.dyson.com
    Sep 08, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
    Suction only coming through the wand when its replaced its not switching back to the upright. I have a dyson DC28 animal
    Best wishes,
    Jack
    Nov 29, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
    Our Dyson Animal DC28 is not transferring the suction from the wand to the floor. After turning on the unit, suction can be felt at the top of the handle wand. Once the unit is leaned to vacuum the...
    Sorry to hear you're having difficulties with your DC28. If it doesn't seem to be picking up as well as usual, it's possible that there's a blockage in the system, and you may need to give the filters a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=1231&product=DC28-ANIMAL
    The correct way to wash the filters is shown in the video below. Under normal use, this should be done at least once every 3-6 months. Use cold water without any detergents, and ensure the filters are totally dry before replacing them - this may take up to 24 hours.
    http://www.dyson.com/support/help.asp?article=1456&product=DC28-ANIMAL
    Hopefully, by clearing any obstructions and washing the filters, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
    Kind regards,
    Jack
    Aug 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
    It is not picking up from the carpet--the exhaust air is coming out the bottom back and not from the top handle--I was not the last to use the vacuum--I think the housekeeper used the handle hose and the...
    Sorry to hear your DC28 Animal is not picking up. To check everything is correct with your machine, please ensure the filters are clean, and the cleaner is free of blockages. This guide from the Support section of our website shows the easiest way to do this:
    Please note the motor exhaust, where filtered air is returned to the room, is located beneath the clear bin. Exhaust air will never come out of the top of the handle.
    If you've checked the machine for obstructions and are still having problems with the performance, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com , so we can provide further assistance.
    Kind regards,
    Jack
    Dyson Customer Service
    Jul 24, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
    I have a brand new Dyson DC28 Airmuscle Vacuumand it is so hard to push and/or pull. Is there a button to make it easier or is it the machine?
    Your DC28 is equipped with Airmuscle™ technology, which allows you to raise or lower the brushbar to suit the flooring you're trying to clean. You should be able to make your DC28 easier to push by changing the setting of the carpet height selector. You can find out how to adjust this in the user guide included with the cleaner. In case you don't have yours to hand, here's an online copy:
    http://media.dyson.com/downloads/US/floorcare/Manuals/dc28_opmanual_usa.pdf
    By raising the brushbar, you should be able to reduce the force needed to push and pull the cleaner. If you've tried this, it may simply be the powerful suction which is making it feel a little heavy to use.
    If you're still concerned, please get in touch with us free on 1866MYDYSON or email askdysonUS@dyson.com. One of our experts will be happy to answer your questions.
    Kind regards,
    Jack
    Jul 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
    I have a Dyson Animal DC28 and the wand won't pull out. This has just happened out of the blue - I was using it with no trouble up to now. I pull up and it just gets stuck. Any help would be...
    I'm sorry to hear you're having difficulties with your DC28 Animal. From what you've described, it sounds as though the hose may have been twisted the last time you replaced the wand on the machine. This is easy to resolve by following these steps:
    • Extend the wand upwards as far as possible
    • With the rear of the cleaner facing you, follow the hose down to where it attaches to the cleaner
    • Whilst stretching the loose section of hose away from the cleaner, pull the hose release tab to detach the base of the hose from the cleaner
    • Allow the hose to untwist itself
    You should now be able to pull the wand out to it's fullest extent, removing it from the cleaner. Once you've done this, simply reattach the lower end of the hose to the cleaner.
    If you have any further questions, or if you'd prefer someone to talk you through this process, you can call us free on 1866MYDYSON.
    Kind regards,
    Jack
    Jun 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Dyson DC07 bagless - upright mode v poor suction, wand mode ok
    From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
    We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
    Kind regards
    Darran
    Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
    169 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
