Question about Friedrich WallMaster WS09A10D Air Conditioner
Turns on then stops running after a minute - Friedrich WallMaster WS09A10D Air Conditioner
    Sergeant:
  • 324 Answers
Check if the air conditioner is set to dry mode instead of cool
Posted on Oct 21, 2013
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
My neighbor changed the steering wheel on a 2001 suburban and now security light is on. Now the truck starts then dies. I need a passlock diagram
Sounds like you need to do a 30 minute security relearn. Basically turn the key to the run position, do not start. Leave it in the run position for approximately 10 minutes. The flashing security light will go out. Turn the key off for 5 seconds. Turn it back to the run position for another 10 minutes. Again the light will stop flashing. Tune the key off and repeat one more time. When the light stops flashing turn the key of and then start the vehicle.
There are also plenty of references to this online as well. Good luck.
Feb 22, 2015 | Cars & Trucks
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Compressor running non-stop
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Sep 23, 2017 | Amana ARB220ZCS Bottom Freezer...
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Friedrich WallMaster WS09A10D Air Conditioner Logo
48 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
