Question about Kenmore Washing Machines
MODEL 45872 NO POWER IT BLEW THE BREAKER - Kenmore Washing Machines
    Master:
  • 818 Answers
Unplug your machine right away-you have a dead short it could be wiring that has rubbed through -check the wiring for any bare spots or rubbing on sharp edges,or its possible the motor is burned up-which means it takes alot of power to start it-more than you house hold wiring can come up with without blowing the breaker-hopefully just a wire though-cheers Denny
Posted on Oct 21, 2013
Model 45872
Unplug it for 15 minutes and plug it back in.
Apr 24, 2014 | Washing Machines
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
While baking there was a spark and smoke that blew out the breaker
Sometimes there are two breakers, one for the 110v and one for the 230v. The 110v works the light and the clock and such, and the 230v handles the heater elements. If the breaker blew, you might need a repair though. Also always be careful when working with electricity please.
Dec 20, 2011 | Frigidaire Kitchen Ranges
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
I have a model #919.167200 5hp, 20gal. air compressor. It has been working great for years, but when I went to turn it on today it blew the breaker. I pulled cover and cleaned contacts on pressure switch,...
Hi dtsorrell...
If your somewhat of a mechanic/electrician then you can by-pass the pressure switch by hooking the color coded motor wires together with the incoming color coded wires from your power cord in the proper order.
Plug it in and then check to see if it blows the breaker again, if it does then it is your motor that is faulty.
Please take time to rate me.
Jul 28, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
Mar 05, 2010 | Electrolux Kitchen Ranges
Hello no power set blew out
I'd tell you ,but I have to bill you too...
Oct 01, 2009 | Astar LTV-3201 32 in. LCD Television
Changed the lite bulb on ge double ge eletric oven and it blew
There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
Dec 21, 2008 | GE Profile JTP56 Electric Double Oven
What can I do?
Sorry, the PS3 does not have a circuit breaker. Most likely when the power came back on the surge blew the power supply. You can get it serviced by Sony or replace the power supply your self.
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
Washing Machines Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
