Question about 02-04 Toyota Camry/Solara, 2AZFE 2.4L Manifold Catalytic Converter"
My 2002 Toyota Solara convertible subwoofer is buzzing. Is this merely an issue with how it is attached between the back seat and the trunk, or is it likely blown? I would like some concept of what is required to fix this before I try tearing the back seat apart.
  • 34 Answers
This type of noise is normally caused by running the power wire and rca's on the same side or side by side. I am assuming it is an aftermarket install and If so I would route the power wire on the opposite side of the rca's. If it is a factory install I would suggest checking all the grounds on the car because they can cause rfi (radio frequency interference) or you may possibly have a defective speaker.
Posted on Oct 22, 2013
How do I remove the rear seats in a 04 Toyota Convertible Solara
If you can't pull seat bottom up at front, ck for bolts at front edge of seat bottom.remove them first ,remove seat bottom. Then bolts for seat back wil be seen at bottom of seat back.
May 15, 2017 | Toyota Cars & Trucks
Can I change a 2002 driver power seat to a manual driver seat? What make and years will work if yes
reach under seat an disconnect the cable an wait for alerts
none ur good
if any then what
quit looking for issues before they happen.
Nov 28, 2014 | 2002 Toyota Camry Solara
What tires fit a Toyota Solara 2002
Standard size is 205/65R15.
Optional size is 205/60R16.
205/55R16 may not be close enough but a tire store should be able to tell you for sure. You would have to have the optional 16in wheels already on the car.
Dec 17, 2012 | 2002 Toyota Camry Solara
Error code p0420 toyota solara
This code is usually stored when there is a catalytic converter failure, the cat converter which is part of the exhaust manifold will most likely need to be replaced.
Feb 16, 2012 | 2002 Toyota Camry Solara
Lost the keys for trunk and trying to fold the back seat ,but sounds impossible .how can i open it?
there should be a trunk release latch in the car my Camry's release latch is on the floor next to my driver side seat it says trunk right on it along with the release for the gas door thats a picture of a gas pump hope this helps you if its not on the floor there look along the underside of your dash for a button some cars even have them in the glove box although i don't think that applies for an older Toyota like yours
Aug 19, 2011 | 2002 Toyota Camry Solara
Trunk wont open with remote or latch inside car 2005 toyota solara
Its probably the cable that runs from the latch to the trunk. This happened to me in my Accord. The part was only $25, but the labor was almost $260, so I just bought the part and did it myself. It was a lot of work (had to take up the carpet a little and take out the seats, but it only took 2 hours with 2 people working on it and I saved $260. hope that helps!
Jan 02, 2011 | 2005 Toyota Camry Solara
Starts intermittently. Turning key results in low
I have the same issue - what fixed yours?
May 11, 2010 | 2001 Toyota Camry Solara
Top will not retract
check all the fuses and check to make sure you have power going to the motor give these websites a try www.autozone.com and www.alldatadiy.com you can also stop by your local Toyota dealership and talk with the service Manger wish you the best of luck Michigan Man.
Nov 27, 2009 | 2002 Toyota Camry Solara
My convertible top will not go up or down.
well try geting checking the fuses then maybe the switch get a test light and see if u have power at the moter
Mar 26, 2009 | 2002 Toyota Camry Solara
2002 Toyota Solara Convertible seat belts not retracting
The front seatblet retractor springs have weakened. Unfortunatly, there are no "user serviceable parts" on them. They would have to be replaced. How many miles is on it? If you have low mileage, the Toyota Customer Experience Center may provide you some assistance, as the belt replacements are quite expensive. I'd call the CEC and explain your dilemma. Here is the number: 1-800-331-4331
Sep 22, 2008 | 2002 Toyota Camry Solara
02-04 Toyota Camry/Solara, 2AZFE 2.4L Manifold Catalytic Converter" Logo
64 people viewed this question
Top Pacesetter Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pacesetter Vehicle Part and Accessory Expert? Answer questions, earn points and help others
