Question about Kenmore Microwave Ovens
Remove filter from microwave oven model #401.85053010
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Posted on Jun 30, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
GE Microwave PVM1870 clean filter
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Jan 29, 2013 | General Electric PVM1870 Microwave Oven
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
How do I change the filter on the Hotpoint RVM1535WMCo01 microwave oven. When I took the top off I can not see a filter to replace. Does that mean that I have been running the Micro for the last year...
Microwave ovens produce dangerous emissions and require servicing by qualified technicians.
I suggest purchase a new one rather than repair because most microwave models cost as much to repair as simply buying a new one.
Nov 02, 2017 | GE Hotpoint RVM1535 Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Where do you install the charcoal filter on spacemaker microwave oven model # jvm1540
remove the two and 3 maybe in the air grill at top of oven . behind inthe center is the filter . ( very pricey // about 60.00 / the make sure it seated properly so the air flow is through filter .. replace front grill and your done .. ****
Jan 09, 2010 | GE Spacemaker JVM1540 Microwave Oven
How do you install the charcol Filter?
Take out the two screws on the top as directed, then slide the grill to the left about 1/2". Then pull it toward you.
Sep 16, 2009 | GE Spacemaker JVM1540 Microwave Oven
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
