Question about Car Audio & Video
Pioneer Wiring Color Codes
I bought a wiring harness for my 99 ford mustang 35th anniversary edition and my Pioneer x65bt comes on and I don't get any sound out of my speakers Do I need to straight wire it?
KaeZoo
  • 156 Answers
SOURCE: Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Posted on Mar 07, 2007
shanat
  • 359 Answers
SOURCE: reinstalling into new vehicle looking for wiring color codes?
yellow (memory 12v+) red (accessories) black (ground earth) blue (power antenna) blue (amp rem) white with stripe (left front speaker + white( left front speaker - )grey with black stripe (right front speaker + grey (right front speaker -) green with stripe (left rear speaker+) green (left rear speaker -) purple with stripe (right rear speaker +) purple (right rear speaker-)
Posted on May 26, 2008
  • 109 Answers
SOURCE: dont know the wiring diagram
Positvie is red, ground is black, and or black with a white stripe. the yellow wire is also a positive wire, it is the memory wire which should be hooked to something that will always be hot, even when the key is completely off. If you have a power antenna, that is controlled by the blue wire
Posted on May 04, 2009
  • 30 Answers
SOURCE: radio wiring harness color codes for 2004 Jeep GC
This is for a 2002 cherokee:
RADIO 12V - red/white
RADIO GROUND - black
RADIO SWITCH - white/red
Posted on May 17, 2009
  • 150 Answers
SOURCE: Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
Posted on May 21, 2009
Wiring diagram
It comes in the box you bought it with, and if you bought the wiring harness you just match the colors up, red is usually positive battery, black is ground, blue is antenna, white and blue is remote for your amplifier just he the manual out, I'm guessing you didn't buy a wiring harness or a antenna adapter
May 31, 2013 | Car Audio & Video
I bought a metra wiring harness for my 93 mustang to put in an aftermarket stereo..stereo powers up but can not get sound to speakers..i triple checked all wires i spliced..all colors match..any...
Don't know the model. Be aware that Ford is whimsical when it comes to color codes and even varies from model to model. Whichever pair the adapter uses for the left door speaker, connect the + wire to the ORG/LT GRN wire and the - wire to the LT BLU/WHT wire. For the right door speaker, connect the + wire to the WHT/LT GRN wire and the - wire to the DK GRN/ORG wire. For the left rear speaker, connect the + wire to the PINK/LT GRN wire and the - wire to the PNK/LT BLU or TA/YEL wire (same wire). For the right rear speaker, connect the + wire to the PINK/LT BLU wire and the - wire to the DK GRN/ORG or BRN/PNK wire (same wire). REMEMBER, the colors of the Metra adapter may not match what's in your car
Sep 27, 2012 | Car Audio & Video
Wiring diagram pioneer deh-p4950mp
If you are installing the radio, I recommend you purchase a wiring harness to your specific vehicle. The wiring harness will have the color code and all you have to do is match colored wires. All aftermarket radios have standardized color codes for their wires. Hope this helps.
Aug 25, 2011 | Car Audio & Video
I have a DEH-P4900IB, and i need the wiring color codes
If you are planning to install this unit, I recommend using a wiring harness. The harness for your vehicle will come with the color codes on the package. All radio wires are standardized. Hope this helps.
Aug 18, 2011 | Pioneer Car Audio & Video
Pioneer dehp3100ub.stock speakers wont work with unit?
If the vehicle has a premium sound package - you need to use the remote wire to turn on the factiry amplifier.
If you want to use the power from the radio for the speakers, you must buy and install a factory amplifier bypass harness.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Pioneer DEH-P3600 CD Player
Wiring diagram or color chart for a 96 ford mustang radio harness
dont even worrie about it just go to walmart or an auto parts and get a wiring harness they are not so expensive
May 28, 2009 | 1996 Ford Mustang
Replaced brake pads 99 Mustang 35th Ann now they are locking up
you have either calipers hanging up or the lines are separated on the inside causing the fluid to not be released back after application of the brakes.. to test... remove the caliper on the pass side first (farther from master cylinder) and slowly try to push the piston in using a c-clamp.. if it doesnt go in SMOOTH then crack the bleeder screw, and try again, if it goes in just fine its the line.. if it goes in the first time fine then go to the other side and try it. if one of them DOESNT go in fine with the bleeder broke open you need calipers (very common) and then you will need to bleed the brakes and make sure to start on the side farthest from the master cylinder i.e pass side
Nov 24, 2008 | 2001 Ford Mustang
Broken into and wires from under the steering wheel broken how to fix
You need to either replace the wiring harness, or get a bunch or ****-splice connectors and reconnect each wire one at a time, making sure you connect the righ wires together using the color codes of each wire.
Aug 03, 2008 | 1984 Ford Mustang
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
