Question about Fujitsu "AOU12RLS 12,000 BTU Cool/16,000 BTU Heat Halcyon Ductless Mi"
AOU12RLS outside unit is knocking or ticking? Any idea what it might be? Nothing appears to be in fan after taking cover off to examine.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Need to check and make sure the condensing fan ( outdoor unit fan) wires are not hitting the fan blade, it could also be that the fan blade needs to be balanced.
Posted on Oct 22, 2013
Zaiko e5 error how I can fix my ac
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in
heat mode. On cooling, the E5 will appear if the outside coil temp exceeds 68C. This is an indication
of condenser airflow reduced or non-existent. Using the procedure described above it is possible to
watch the condenser coil temp using the Temp down button and Medium fan speed combination to
display this temp. NB: if fans etc seem to be OK then measure thermistor resistance and refer to table
12. In case the problem is thermistor calibration.
Action: If unit is in cooling mode, examine both condenser fans are running. If
one is running then suspect a faulty motor. If both fans not running then
on units up to serial No. IBSA 01175, investigate the fan speed control
card located in enclosure on the LHS See fig 6.
If this checks OK then investigate main control card.
Fig 1, 2 or 3. Units with serial No's IBSA01176 and
onward are multi speed tapped wound motors not requiring a speed
control card. If both motors inoperative then suspect main control card
Aug 15, 2016 | Heating & Cooling
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Ticking Noise in my Fujitsu Mini Split Indoor Unit
does the ac continue to make the noise even in fan only mode or is only in cooling mode. If only in cooling then it could be a gas related problem or blocked coil.
Nov 07, 2014 | Fujitsu 12RLS Wall Ductless Air...
1993 3000GT LIFTER TICK
generally a car of that age is going to have a lifter ticking. it's usually nothing to worry about but can be fixed. basically you will have to take of the manifold covers and unless you know which one is ticking you will need to adjust/replace all of them. just don't get a lifter ticking confused with an engine knocking.
Jul 13, 2012 | 1993 Mitsubishi 3000GT
Red screen shows video though....been used outside behind a bar area covered by a roof and walls but front wall is open by the swimming pool....any suggestions.
Yes, the unit has a fan that runs 7/24 when unit is plugged to power--moisture likely has got into the set and may have damaged boards.
Someone would have to open it and closely examine the main board where the fan is located at.
May 28, 2012 | Panasonic Th-50pe700u TV
2001 S Type V8- moderate to loud ticking sound in the engine (sounds like metal to metal contact). The ticking is constant, at idle or throttled. One mechanic thought it might be the #8 lifter spring?
Thanks for choosing FixYa and welcome. That is possible. More then likely, it is a associated with the valve lifter. If it was a rod, you would hear a knocking sound compared to the ticking sounds a bad lifter gives off. As far as which lifter it is, the only way to know for sure if by taking off the valve cover and examining the lifters. You are in the right area though. Check your lifters and you should fine what is causing the ticking. Put all your focus on that area. Your friend sounds like he knows what he is talking about so he may be able to help you work on it if you are not able.
Sep 24, 2011 | 2001 Jaguar S-Type
2009 Ford Flex when started first thing on a cold morning it ticks/knocs really really loud, once it warms up the ticking goes away to a very light tick. The dealership ruled out an exhaust manifold leak....
It does sound like a valve lifter problem to me also. It should be covered under warranty. It's a mechanical failure of a component of the drivetrain. Ask them to show you the specific exclusion if they say it's not a warranty problem.Powertrain warranty is 60 months/60,000 miles ( which ever comes first).
Mar 30, 2011 | 2009 Ford Flex
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
A/C quit running
This question is really to broad to answer. There are several things that could cause it to stop running. I think I would turn everything off, let it cool down for several hours and try it again. When you kick it back on, take note of what is running and what's not running. Inside fan, outside fan, compressor. If the outside unit will not run at all it could be as simple as a grasshopper caught in the contacts. If you hear the compressor running outside but no outside fan, The fan motor probably needs replaced. Please make sure that all power to the unit is TURNED OFF before removing cover plates on outside unit and before trying to remove insects from contact points. Check all wiring inside outside unit while it is open. Also check capacitors for swelling or leaking. If you don't know how to turn all the power off or open the outside unit, you need to call a professional AC technician. Hope this helps. kstfas
Aug 26, 2007 | Ruud UAKA037 Air Conditioner
Fujitsu "AOU12RLS 12,000 BTU Cool/16,000 BTU Heat Halcyon Ductless Mi" Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
