Question about Frigidaire GLTF2940F Front Load Washer
The washer will not turn on. It will say Err but no number. It appears that the door will not lock. Is there a simple solution??
    New Friend:
  • 50 Answers
CONTROL penel error
Posted on Oct 22, 2013
2 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: MY fridgadaire lg washer says loc and wont let the door lock and machine start
That is a door lock malfunction, check the lock and wire harness connections.
Posted on Oct 29, 2008
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
I go to start my washer and get an ERR LOC problem. Model Number GLTF2940ES1. What can I do to fix the problem
Hi
That is a door lock malfunction, check the lock and wire harness connections. Also turn the selector knob so the machine comes on then press the "options" and "select" buttons at the same time for 3 seconds.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 03, 2011 | Frigidaire GLTF2940ES Front Load Washer
It washes then it stops, then it read err
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further assistance.
Dec 29, 2010 | Frigidaire ATF6000ES Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washing machine
Sounds like it needs replacing from what you have said. You could try to free up the locking mechanism by going behind the lock on the washer from the top and the door catch. If this fails to solve the problem, then you will need to buy a new unit. You will get one online from Seme Nedis Ltd. You will should find the washer model number on the outer edge of the door. I hope this has been of some help to you.
Nov 29, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer (laundry)
try pressing options and select for ten seconds if that doesnt work you have a promblem with the door lock switch open then shut your door firmly try it again if that doesent do it try unplugging the unit for 5-8 seconds then retry if that doesnt do it then pull the bottom panel and look on the left side of the washer there will be a envelope with a tech sheet there with instructions on testing the door lock itself
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
New frigidaire washer (affinity)
Kimberely, The err 47 means that the control board is not sensing the door lock. First try unplugging the machine for 1 minute and see if it comes back to normal. If it doesn't put it into the door lock test, with the door closed, by doing the following: Turn the program knob to drain spin. Press pause cancel to turn off the LEDs. Within 5 seconds, press and hold the option and pause cancel buttons until the LEDs start sequentially chasing, then release the buttons. All the LEDs will sequentially light. Turn the program knob 4 clicks from the start position clockwise, the door lock solenoid will activate. The door should be locked. Turn the knob one more click clockwise and it should unlock. You can toggle back and forth to test it. If the door lock is working and you are still getting this code, then its a control board problem. You should call for factory service. If you have any more questions, you can email me at catriver1@gmail.com Catriver...post back.
Jan 20, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire GLTF2940F Front Load Washer Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
