Question about Bell Cocoon Child Carrier
How do i change a Jegs JN152 doorbell channel
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
How do I change the battery in the wireless doorbell button?
are you to take it off the wall
if so it should have either two screws or slide off door
Feb 01, 2009 | Desa International White Wireless Plug In...
Heath Zenith 6150 wireless doorbell
Yes, there is a way to change the security code. See FAQ here:
http://www.heath-zenith.com/servsup_disp_faq.cgi?cat=5
click on "how can I change the security code."
Jan 06, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Doorbell/cartel
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
Tones 01,04 and 05 tend to be reasonable.
Carl
Aug 01, 2008 | Panasonic KX-T7633 Corded Phone
Bell Cocoon Child Carrier Logo
408 people viewed this question
Top Bell Sport & Outdoor - Others Experts
ray gallant
Are you a Bell Sport and Outdoor - Other Expert? Answer questions, earn points and help others
