Question about Kitchen Ranges
Ge 317b6641p001 Oven has black soot and chunks of black material in the broiler pan. Strong odor when first lighting. Faint soot marks on wall behind stove.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Does the broiler still work? If not, the broiler element has burnt thru and needs to be replaced. Here is the part to order.
Posted on Oct 21, 2013
4 Suggested Answers
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: i am looking for a broiler pan for my GE oven. the
All you have to do is go to any appliance parts and give them the model number they should be able to get it for you
Posted on Nov 03, 2009
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
I have a GE 317b6641p001 and burners light but not the stove...any help out there?
do you mean oven doesnt light?
may have a bad oven coil
not hard to change just a few screws
remove and check power
Jan 04, 2015 | GE / Hotpoint Stove Top Heating Element...
Call sumary lock
  • TSP or Trisodium Phosphate cleaner (1 tbsp.)
  • Rubber gloves for cleaning
  • A Large sponge or the sponge used while washing your car. A lot of cleaning needs to be done, and the sponge should be large enough to soak up a lot of water in one go
  • 2 large buckets
  • Warm water
  • Goggles and a mask to protect eyes and face
  • Rags to clean
After you put on your heavy-duty gloves, use the sponge and soak it into the TSP solution. The TSP solution contains a gallon of water and a tablespoonful of TSP. Work section-by-section, focusing on one segment and wall at a time.
First, wipe the surface of the wall or ceiling with the sponge and use hard and firm strokes. After that, dip the rags in clean warm water and rinse the ceiling and walls. Do the same with the other segments until everything has been cleaned properly.
The frequency of the above step may be more than one. It depends on the condition of the house after the fire and how much charring and soot buildup has occurred. You must be careful not to over-wash your ceilings and walls because seepage of water might occur into the drywall or baseboard. Don't saturate your walls with TSP and warm water.
This step is often followed by priming all the walls damaged by the fire and then adding a fresh coat of paint. There might be a lot of soot buildup in the AC filters, and they should be removed. All appliances should be thoroughly cleaned using a disinfectant. A fresh sealing layer needs to be applied on all the surfaces affected by the soot.
A simple deodorant or room freshener doesn't have a smell strong enough to counteract the bad odor from smoke. To deal with smoke, something stronger has to be used to disable odor causing smoke molecules in the air. Below are some items that can help you kill the odor from smoke damage:
Tony
May 30, 2014 | Nokia 1100
Ge range 317b6641p001
Get an oven thermometer to see how off the temperatures really are.
Dec 17, 2013 | Kitchen Ranges
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Oven produces soot when running, broiler ok, stove top ok
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Ge gas oven
Remove the burner tube that you said has soot on it and clean it out. This will give you a cleaner burn.
Jul 20, 2008 | Ovens
Kitchen Ranges Logo
116 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
