Question about Firestone 2404 - 1999-2012 Ford F550 2wd/4wd w/o Factory Bed - ride-rite Air Bag Helper Springs [rear]
2012 f550 6.7 diesel air conditioning is not working right because of high side pressure is very high and put water to the front condenser then truck get cool and pressuere normal
  • Firestone Master
  • 9,771 Answers
Look for a bad expansion valve in the evap. Also you can get an oil plug in the condenser tubing that will raise the pressure too.
Posted on Jan 29, 2014
Why does my ford f350 6.0 diesel start then shuts off and wont stay running.
I have a chevy c3500 with a 6.5 turbo diesel, the times that it has happened
to me was because of a dirty fuel filter or water, most diesel have a bleed off
valve to dissipate any accesss water in the fuel line, on my truck is located
on the right front side of the engine . you bleed it off when the engine is
turned off. good luck
Jul 21, 2011 | 2005 Ford F 350 Super Duty
Ford 99 diesel air condition cuts out after driving down road. works great while driving until you stop at light, then shortly after driving again it will stop. the compressor clutch stops spinning. if...
when it kick of if you hit the cluch of compressor with anything you got does the compressor start you might have a weak coil when it get warm it not strong enought to keep the cluch ingauge hope it help pierre
Jul 19, 2008 | Ford F-250 Cars & Trucks
How do i hook my manifold gauges to my residental condensing unit to check pressures
The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
Jul 24, 2010 | Heating & Cooling
2007 Ram Truck: where is low side of ac to recharge in 2007 dodge ...
The Low Pressure Side connector will be smaller than the High Pressure Side connector so the refill hose will fit properly only on the Low Pressure Side.
Read more: How to Recharge Air Conditioning with Freon in a Dodge Ram | eHow.com http://www.ehow.com/how_4484569_recharge-air-conditioning-freon-dodge.html#ixzz0uLXJnwvE
May 17, 2010 | 2007 Dodge Ram Truck
Condenser Fan not working when the Air Cond is On.
There is a high pressure switch on the high side of the ac system,it most likely is bad.
Apr 06, 2010 | 1996 Mercedes-Benz C-Class
I have a 99 chevy suburban that won't cool past 60 degrees and when idling is at 70 degrees. I have replaced the a/c compressor, orfice tube,the accumilator,rear expension valve, and fan clutch. My low...
These numbers are a little high depsite the high ambient conditions.Amazingly enough ,automotive low side suction pressure will equal the degrees its putting out at the evaporator coil...for instance,70 psi low side pressure will produce about 70 degrees of cooling. At 300 psi on the high side(which is high) this is about as low as the suction pressure will go....you need it to go lower.I would probably be concerned with the freon level as a slight overcharge could boost these numbers.Poor air flow through the condenser can also create a higher head pressure than desired.If possible,I would evacuate and re-charge the system with the correct amount of 134a refrigerant. Try to get those pressures lower...about 250/50 would be a decent pressure value in this ambient condition.Verify good airflow through the coils and pay close attention to any foreign debris like plastic grocery bags or wrappers covering the coils...Ive even seen these make their way between the small gap between the condenser and radiator so use a light and inspect carefully for this.Air flow through that condenser coil is vital and any deficit there will create high head pressure which obviously causes high suction pressures....good luck
Jul 29, 2009 | 1999 Chevrolet Suburban
Low-pressure port I need identification
Basic AC system consists of Compressor pump (on engine), Condenser (front grill with radiator) and Evaporator (Firewall). Pump has two ports output (high pressure) and return (low pressure). Follow lines from pump. High side is usually between pump and condenser. Follow lines and find second port this will be low side (refill) port. Paint or replace port caps (red high, blue low). Also, refrigerant in system determines port size (R12 or R34).
Jun 24, 2009 | 2001 Chevrolet Malibu
I cannot differentiate between the low pressure and high pressure
This is a little A/C 101. Follow the A/C lines. All A/C systems have a high pressure side and a low pressure side. The high pressure side is from the compressor to the condenser coil on the front of the vehicle to the evaporator coil in the dash. At the expansion valve in the evaporator the pressure drops. At the expansion valve the refrigerant changes from a liquid to a gas. This provides the cooling. The low pressure side is from the evaporator back to the compressor. Usually the high pressure lines are smaller than the low pressure (suction) lines.
Jun 13, 2009 | 2003 Chevrolet Silverado 1500
Mechanic said car nedds new condensor, is the condensor in the radiator ?
The condenser is part of your air conditioning system. Hot high pressure freon gas from your air conditioning compressor will run through your condenser to dissipate heat and condense into a liquid.
The condenser is not in the radiator but looks like a small version of your radiator mounted either in front of, or behind your main radiator.
If your AC works properly and doesn't leak, then you don't need a condenser.
Jul 23, 2008 | 2000 Kia Sportage
Firestone 2404 - 1999-2012 Ford F550 2wd/4wd w/o Factory Bed - ride-rite Air Bag Helper Springs [rear] Logo
110 people viewed this question
Top Firestone Air Tools & Compressors Experts
Lawrence Oravetz
DonziGT230
DonziGT230
Are you a Firestone Air Tool and Compressor Expert? Answer questions, earn points and help others
