How do I reset a technics sa-gx350 receiver unit
  • 3 Answers
Don't know that you can actually reset this unit like the new digital receivers. It does have protection circuitry that will shut the unit down in case speaker wires are shorted or if speaker impedance is less than the indicated rated impedance of the amp. do the following:
1. Turn off power and unplug from wall.
2. Check all connections and correct if needed.
3. Turn back on after 1-2 minutes.
If unit is still in protect mode you may want to unplug everything from the unit and then power back up to see if the problem is internal or external. If it powers up correctly then the problem is external. Power back down and plug in one external item at a time and power back up between connecting each item to see which item causes the receiver to go into protection mode.
If problem seems to be internal I'd recommend taking to an electronics repair shop if you aren't comfortable with taking apart to check fuses, terminations, etc. There may be a 5-amp fuse in the power plug head also.
Posted on Oct 21, 2013
3 Suggested Answers
SOURCE: How to set tuner presets in Technics SA-GX550 receiver
The user manual is available free at:
http://support.panasonic.co.nz/docstore/SAGX550%20Book.pdf
Posted on Jun 26, 2008
SOURCE: My Technics sa GX350 tuner
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Posted on Jan 10, 2011
How do i hook up my lg smart tv to my technics SA-GX350 stereo reciever
Connect audio outputs of TV to corresponding audio inputs on rear of receiver
Oct 22, 2016 | Technics Audio Players & Recorders
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
Nov 12, 2014 | Audio Players & Recorders
Technics receiver SA-GX350 Receiver Manual states to be only used with 8 ohms speakers. I've used 6ohm speakers with this receiver for over 20 years. Please explain is it safe to do so?
its not safe but manageable.if the speaker impedance is too low, the amplifier will tend to overheat and more power is used up in the amplifier than is delivered to the speaker. Too many speakers on a solid state amp can burn up the power output section.
Oct 26, 2014 | Audio Players & Recorders
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Jan 01, 2011 | Technics SA-AX910 Receiver
AV stereo rec SA-GX550 GX350 Shuts down while operating. Resumes playing after random interval. Does not pass 110VAC to ancillary equipment through AC plug in back of console. Please advise.
Technics? check for bad solder connections on the voltage regulators attached to the heatsink. some models have an acess panel you can cut out on the bottom of the receiver. you will have to find a screw or two to re-attach the panel. it could also be a problem with the cooling fan.
Good Luck
Oct 21, 2009 | Audio Players & Recorders
Technics SA-GX350 Nonfunctional - Click, then nothing.
Please update the initial posting and continue the diagnosis there. The initial response is repeated below.
Thanks,
Dan
Initial response:
There could be a number of reasons for this. It woyld help if you could indicate what resistors you changed. The circuit designation should be marked on the PC board. Please post those here and I'll look further and provide some possible solutions.
Thanks,
Dan
Jul 20, 2009 | Technics Audio Players & Recorders
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
93 people viewed this question
 Grubhead
Grubhead
